Atwater Kent model 1100
5/23/2010 8:48:41 PMGeorge
Hi all...I picked up a Atwater kent radio in a Pooley cabinet. I am not all that familiar with Atwater Kents..but this radio/cabinet is going to be a fun project to work on...not in the best of shape but restorable.. The only info (model #s and such) I can get off this set is a metal tag that says "model 1100" ..The cloth tag on battery power cord is no longer readable.. The radio seems quite simple with ony 4 battery connectors. The front of the radio pannel from left to right is as such.. tuner, 3 pole setting, tuner, tuner, and then two knobs for dector and volume with on/off switch underneath.. It appears to me to be a model 20C..perhaps? Could this be the 20C "big box because it has ONLY 4 battery connectors ( 22V and 6V..??) Anyway I am not sure of how to hook up the 4 battery connectors... To what power supplies? I believe it is.. from the back of chassis from left to right it is -22, 22, -6, 6...Please correct me if I am wrong..Also would this set use all O1A tubes?...Also any pictures on ony site of this model 1100?? I have been searching with little success
5/23/2010 9:07:46 PMWarren
Here is a bunch of Atwater Kent information. Hunt through this stuff to find the best match for yours.
http://www.atwaterkent.info/TechData/akSvcDataIndex.html
5/23/2010 9:21:24 PMAHHHH Thank you warren..george
:Here is a bunch of Atwater Kent information. Hunt through this stuff to find the best match for yours.
:http://www.atwaterkent.info/TechData/akSvcDataIndex.html
