silvertone catalog # vs. model #
5/10/2010 10:53:01 PMScott Matusek
Hello everybody! Just picked up a Silvertone console and I'm having trouble finding a schema for it. On the back of the unit there is three different cat. numbers 7061, 7062, 7063. I can't find a schematic using these, I think they only correspond to the options of the finish on the cabinet. It has a chassis number, 528.46200 But still having no luck finding a schema using that number as well. Any suggestions will be greatly appreciated. Thanks in advance!
5/11/2010 8:41:22 AMScott
The 7601 etc numbers relate to the record player part of the console. Anything else on the radio part of the console? Got a tube line up?
5/11/2010 9:42:31 AMBill VA
Scott, you're right about the model number defining the finish. You need SAMS Photofact 366-11. Later today I will have a chance to pull the SAMS and send to you. You can use the SAMS site to check for schematic data on items 1946 and forward. I just used an index I had.
But,here. https://www.samswebsite.com/en/photofact/search?s=Search&t=model&o=0&k=7061&submit=Search
Bill
:Hello everybody! Just picked up a Silvertone console and I'm having trouble finding a schema for it. On the back of the unit there is three different cat. numbers 7061, 7062, 7063. I can't find a schematic using these, I think they only correspond to the options of the finish on the cabinet. It has a chassis number, 528.46200 But still having no luck finding a schema using that number as well. Any suggestions will be greatly appreciated. Thanks in advance!
5/11/2010 4:16:30 PMScott Matusek
Thank you very much Bill and Scott, I am anxious to get this one going. The cabinet is in great condition as well as the chassis itself. The record player is not in very good condition, but probably fixable (missing tone arm and bent center pin). The tube line up is as follows, 5u4gb, 2- 6v6gt, 6ba6, 6av6, 6cb6, 6al5, 6u8, another 6ba6, 12ax7, and 6e5 magic eye (which is very weak). Most of which are still the original silvertone red lettered bases. Thanks again for everyones help.
:Scott, you're right about the model number defining the finish. You need SAMS Photofact 366-11. Later today I will have a chance to pull the SAMS and send to you. You can use the SAMS site to check for schematic data on items 1946 and forward. I just used an index I had.
:But,here. https://www.samswebsite.com/en/photofact/search?s=Search&t=model&o=0&k=7061&submit=Search
:Bill
::Hello everybody! Just picked up a Silvertone console and I'm having trouble finding a schema for it. On the back of the unit there is three different cat. numbers 7061, 7062, 7063. I can't find a schematic using these, I think they only correspond to the options of the finish on the cabinet. It has a chassis number, 528.46200 But still having no luck finding a schema using that number as well. Any suggestions will be greatly appreciated. Thanks in advance!
5/11/2010 7:04:26 PMBill VA
SAMS sent. Good luck.
Bill
:Thank you very much Bill and Scott, I am anxious to get this one going. The cabinet is in great condition as well as the chassis itself. The record player is not in very good condition, but probably fixable (missing tone arm and bent center pin). The tube line up is as follows, 5u4gb, 2- 6v6gt, 6ba6, 6av6, 6cb6, 6al5, 6u8, another 6ba6, 12ax7, and 6e5 magic eye (which is very weak). Most of which are still the original silvertone red lettered bases. Thanks again for everyones help.
::Scott, you're right about the model number defining the finish. You need SAMS Photofact 366-11. Later today I will have a chance to pull the SAMS and send to you. You can use the SAMS site to check for schematic data on items 1946 and forward. I just used an index I had.
::But,here. https://www.samswebsite.com/en/photofact/search?s=Search&t=model&o=0&k=7061&submit=Search
::Bill
:::Hello everybody! Just picked up a Silvertone console and I'm having trouble finding a schema for it. On the back of the unit there is three different cat. numbers 7061, 7062, 7063. I can't find a schematic using these, I think they only correspond to the options of the finish on the cabinet. It has a chassis number, 528.46200 But still having no luck finding a schema using that number as well. Any suggestions will be greatly appreciated. Thanks in advance!
