Philco Model 511 Pilot Lamp and #913 Display Tube
5/9/2010 6:15:08 AMLou
Hello:
I have two questions for the forum today:
1. Who knows the proper type # pilot lamp that goes into a Philco model 511 TRF set? The data I have on it only references a Philco part #.
2.Does anyone happen to have in their tube inventory an RCA number 913 display tube? This is a tube that looks like a metal 6L6 but has a glass window at one end. It is a 1 inch osilloscope tube ( yes - 1 inch!!).
Thanks for any info!!
Lou
5/9/2010 10:09:57 AMWarren
Here is a link for the Philco dial lamps.
http://www.philcorepairbench.com/lamps.htm
Have seen that 1 inch tube before in a stereo receiver.
5/10/2010 10:36:27 AMLou
Unfortunatley the Philco literature only shows a code # for the lamp - it does not match any of the numbers on the dial lamp list you referenced.
Lou
:Here is a link for the Philco dial lamps.
:http://www.philcorepairbench.com/lamps.htm
:Have seen that 1 inch tube before in a stereo receiver.
5/10/2010 11:51:50 AMNorm Leal
Lou
The lamp is across a 2.5 volt filament winding. Unless it's an unusual socket use #41 or #42 lamp.
There are other 1" CRTs but they don't have the metal shell. Are you planning on building a project with one?
:Unfortunatley the Philco literature only shows a code # for the lamp - it does not match any of the numbers on the dial lamp list you referenced.
:Thanks
:Lou
::Here is a link for the Philco dial lamps.
::http://www.philcorepairbench.com/lamps.htm
::Have seen that 1 inch tube before in a stereo receiver.
5/10/2010 4:04:31 PMLou
PS
I bought an oscilloscope at Deerfield that uses this 1 inch tube, believe it or not. I plan to restore it
:Lou
: The lamp is across a 2.5 volt filament winding. Unless it's an unusual socket use #41 or #42 lamp.
: There are other 1" CRTs but they don't have the metal shell. Are you planning on building a project with one?
::Unfortunatley the Philco literature only shows a code # for the lamp - it does not match any of the numbers on the dial lamp list you referenced.
::Thanks
::Lou
:::Here is a link for the Philco dial lamps.
:::http://www.philcorepairbench.com/lamps.htm
:::Have seen that 1 inch tube before in a stereo receiver.
