I need a plan to track down the problem and remove it. I thought I would start with disconnecting C10 from the volume pot,the signal to the 6J5 the 1st IF tube, and see if the hum stays or disappears. If it stays I know it is in the audio/amp section of the radio. If not it is back in the detection section, correct??? Beyond this I am slightly lost. Like I said, I need a plan or some things to look for common to THIS radio. Way past swapping out obvious parts.
Any of you Guru’s out there can help a brother radio guy out? Unfortunately Google is my professor and I have been learning by doing. This radio has so many parts to it gets real crazy real fast. Any points I can check for continuity or whether ground should be there or not? Thanks for any help.
Is hum there with volume turned down? Did you notice negative of filter caps connect to center tap of the high voltage winding rather than chassis?
C21 positive goes to chassis, ground.
Are shields in place on audio tubes, 6J5G? If you replaced these tube with metal types is pin #1 grounded? Zenith didn't always have a pin #1 in their tube sockets.
http://www.nostalgiaair.org/PagesByModel/734/M0024734.pdf
:I have a beautiful Zenith 12S265 that has a hard to fix hum. I recieve many channels and she is loud as hell but I constantly get a mid to low volume hum all the time. I know this is not normal, have restored this zenith chassis before and it isn’t my house AC lines. I love it because when I get a good song playing it literally rattles the windows with bass and sends the cats running. It is so close to working well that it haunts me in my sleep. It really does. I need some help locating the issue and hope someone can give me some direction on locating the problem.
:Not new to repairing Zeniths so I have some knowledge on what is going on. Any help is greatly appreciated.
:Here is what has been done so far.
:1. I have recapped the whole radio and have double-checked every connection to be correct. All new caps and all old style “linken log” resistors have been replaced with equivalent sizes.
:2. Completely swapped out the toxic bar resistor with high quality 5 Watt resistors equal to the original resistances.
:3. Checked and swapped out with different tube all the 12 tubes to make sure it wasn’t a bad tube causing the hum.
:4. Cleaned ALL sockets and selector switches.
:5. New electrolytic caps at schematic listed sizes.
:6. Speaker has been re-coned and old voice coil replaced and the original speaker field coil is still intact. Ohms out good.
:7. All tube shields in place and variable tuning capacitor has been thoroughly cleaned along with isolating rubber grommets replaced with new. Brass connecting forks cleaned.
:I need a plan to track down the problem and remove it. I thought I would start with disconnecting C10 from the volume pot,the signal to the 6J5 the 1st IF tube, and see if the hum stays or disappears. If it stays I know it is in the audio/amp section of the radio. If not it is back in the detection section, correct??? Beyond this I am slightly lost. Like I said, I need a plan or some things to look for common to THIS radio. Way past swapping out obvious parts.
:Any of you Guru’s out there can help a brother radio guy out? Unfortunately Google is my professor and I have been learning by doing. This radio has so many parts to it gets real crazy real fast. Any points I can check for continuity or whether ground should be there or not? Thanks for any help.
I have the negative of C26 and C27 goin to the center tap and the positives going to the speaker field. Will check again tonight but confident that they are. What was there to begin with was a cob job.
Got to check on the C21 positive is going to chassis ground. I will triple check.
I have glass 6J5s in place. Not all of them have shields just the ones that had them originally. The Osc. 6J5 is on the left and has shield which means there are definitly three without on the right. I DID NOTICE THE #1 pin is not connected to even a receptical on the socket for these tubes. Should I render this for glass tubes to?
Since hum is there with volume tuyrned down work on circuitry to right of the volume control in schematic. Wouldn't worry about the volume control or anything to the left.
The two audio 6J5G's have a ground symbol going to outside. This would usually mean tubes have a shield?
Hum is in the power supply or audio portion of your radio. Be sure any old electrolytic caps have been electrically removed. Try bypassing electrolytic caps and see if there is a change in hum.
Leakage between cathode and filamement can cause hum but this isn't as common..
:Hi Norm, I thank you for your help.
:The hum IS there when volume is all the way down. Indication of something? I was thinking bad internals to the volume pot creating hum. Have come across this before but it feels smooth to the turn and it controls volume well. Thoughts?
:I have the negative of C26 and C27 goin to the center tap and the positives going to the speaker field. Will check again tonight but confident that they are. What was there to begin with was a cob job.
:Got to check on the C21 positive is going to chassis ground. I will triple check.
:I have glass 6J5s in place. Not all of them have shields just the ones that had them originally. The Osc. 6J5 is on the left and has shield which means there are definitly three without on the right. I DID NOTICE THE #1 pin is not connected to even a receptical on the socket for these tubes. Should I render this for glass tubes to?
Was any shielded wire replaced? If so it needs to be shielded again.
:Hi Joe
:Since hum is there with volume tuyrned down work on circuitry to right of the volume control in schematic. Wouldn't worry about the volume control or anything to the left.
:http://www.nostalgiaair.org/PagesByModel/734/M0024734.pdf
:The two audio 6J5G's have a ground symbol going to outside. This would usually mean tubes have a shield?
:Hum is in the power supply or audio portion of your radio. Be sure any old electrolytic caps have been electrically removed. Try bypassing electrolytic caps and see if there is a change in hum.
:Leakage between cathode and filamement can cause hum but this isn't as common..
::Hi Norm, I thank you for your help.
::The hum IS there when volume is all the way down. Indication of something? I was thinking bad internals to the volume pot creating hum. Have come across this before but it feels smooth to the turn and it controls volume well. Thoughts?
::I have the negative of C26 and C27 goin to the center tap and the positives going to the speaker field. Will check again tonight but confident that they are. What was there to begin with was a cob job.
::Got to check on the C21 positive is going to chassis ground. I will triple check.
::I have glass 6J5s in place. Not all of them have shields just the ones that had them originally. The Osc. 6J5 is on the left and has shield which means there are definitly three without on the right. I DID NOTICE THE #1 pin is not connected to even a receptical on the socket for these tubes. Should I render this for glass tubes to?
Zenith Working Schematic mark-up: ![]()
:Awesome. Forgot about being able to remove tubes. I can't wait to get home tonight and get my beauty working tonight. I WILL let you know what I find tonight. Thank you, I have something to go on now.
Working Schematic Mark-up: ![]() |
IPAddress: ***.225.162.168
