I do know that loops often pick up better than similarily mounted long wire antennas, perhaps due to the balanced nature. A long wire will, of course, pick up well if placed outside, far from interference producing objects.
All of my radios can pick up distant stations (including the Majestic 180 TRF and the small Majestic International 4 tube + ballast TRF (unknown manufacturer or model number), but some just do it better. ...Zeniths especially. My 1949 Mercury radio by Zenith pulls in stations all across the nation with ease, and from Canada, too, with little interference. Of course it has a lot of interference supression built into it. I always resort to a Zenith portable when none of my other radios will pull in a signal due to interference. It'll get the job done. Both my 5 and my 6 tube Zeniths do an excellent job.
::For a long time I have been puzzled why some radios are able to receive AM radio stations in shielded and noisy environments better than others. I rotate old radios on my desk at work, which is on ground floor inside a building with stone outside walls, and steel studs in the walls. There is a large window. There are computers throughout the building, including one on my desk. I have a short wire antenna, which is routed around my desk, as far away from computer / pnone as I can get it, and runs zig - zag across the window glass. My comments apply with the venitian blind all the way up. I can only get strong local stations on most old and all new radios, whether I use my antenna arrangement, and / or the antenna loop inside the radio, as applicable. Homebuild regenerative receivers have probably worked the best. Right now I have a GE Model 321, with an internal loop, and provision for an external antenna, which I have connected. The 12SK7 has been replaced by a 12SH7, just because I have tons of them, and have acquired a lot of radios with tubes missing. So here I am in Austin Texas, listening to Waco and San Antonio - 100 miles in opposite directions. Before everybody came in this morning and turned on their computers, I was listening to Dallas, 200 miles north. Any explanation? By the way, the radio I have at work today is the old style GE 321, with an LC filter (no tuner section) between RF amp and 12SA7. It will be interesting to see how a newer style GE 321 with only RC coupling does. I will swap out rados and check next week.Ed M
:It sounds to me like you could be talking about the old "selectivity vs. sensitivity" issue.
::Dave,
::Sounds like a good subject to expand. Both are at the mercy of alignment, but the antenna system and front end (RF amp/if any) contribute mostly to sensitivity, whereas the IF subsystem determines ultimate selectivity. Oscillator tracking must be "dead on" under all circumstances. Although it hasn't been discussed on this Forum, I'm inclined to think that AVC/AGC should be disabled in all cases for final tweaking, then performance evaluated with AVC/AGC active. Variable gain stages (RF/IF) have been discussed extensively in trade journals for years with the same conclusion. The performance of both vacuum tubes and solid state devices deteriorate rapidly when gain adjustments (bias alterations outside optimum) are applied autominously. I reserve judgement for the latest innovation of digital Radio/TV
::marv
::::For a long time I have been puzzled why some radios are able to receive AM radio stations in shielded and noisy environments better than others. I rotate old radios on my desk at work, which is on ground floor inside a building with stone outside walls, and steel studs in the walls. There is a large window. There are computers throughout the building, including one on my desk. I have a short wire antenna, which is routed around my desk, as far away from computer / pnone as I can get it, and runs zig - zag across the window glass. My comments apply with the venitian blind all the way up. I can only get strong local stations on most old and all new radios, whether I use my antenna arrangement, and / or the antenna loop inside the radio, as applicable. Homebuild regenerative receivers have probably worked the best. Right now I have a GE Model 321, with an internal loop, and provision for an external antenna, which I have connected. The 12SK7 has been replaced by a 12SH7, just because I have tons of them, and have acquired a lot of radios with tubes missing. So here I am in Austin Texas, listening to Waco and San Antonio - 100 miles in opposite directions. Before everybody came in this morning and turned on their computers, I was listening to Dallas, 200 miles north. Any explanation? By the way, the radio I have at work today is the old style GE 321, with an LC filter (no tuner section) between RF amp and 12SA7. It will be interesting to see how a newer style GE 321 with only RC coupling does. I will swap out rados and check next week.Ed M
:::It sounds to me like you could be talking about the old "selectivity vs. sensitivity" issue.
:Most alignment service information says to turn the volume control on the set all the way up, and keep the output of the signal generator turned up just enough to get a signal on the output meter. This is to keep the AVC/AVG voltage down. The AVG lead can also be disconnected or disabled.
:I also agree with the point about how the IF coils are constructed. The old massive slug-tuned coils with those huge pieces of ferrite, (you know, the ones you can turn with a regular screwdriver), are A LOT less sensitive than ones using the hex driver. There have been some articles, (although I can't find one right now), about switching out IF cans to upgrade performance. I know some Hams do this to to increase selectivity in their recievers.
:Anyway, that's my 2 cents.
:Terry
