6B7 adaptor to a more modern equivalent.
4/19/2010 11:00:58 PMDave Froehlich
Hello All,
I don't have a 6B7 for my radio. But I can probably make an adaptor. But What tube is most like a 6B7?
"Twin Diode - Remote Cutoff Pentode" That's a "7D" tube outline. 6.3 volt filament.
4/19/2010 11:06:52 PMDave Froehlich
Hello Again All,
It's a 6B8 that could be adapted to a 6B7 socket. I might have one of those.
:Hello All,
: I don't have a 6B7 for my radio. But I can probably make an adaptor. But What tube is most like a 6B7?
:"Twin Diode - Remote Cutoff Pentode" That's a "7D" tube outline. 6.3 volt filament.
:Thanks,
:Dave
4/20/2010 11:20:17 AMNorm Leal
If you want a 6B7 send an email.
:Hello Again All,
: It's a 6B8 that could be adapted to a 6B7 socket. I might have one of those.
:Thanks,
:Dave
::Hello All,
:: I don't have a 6B7 for my radio. But I can probably make an adaptor. But What tube is most like a 6B7?
::"Twin Diode - Remote Cutoff Pentode" That's a "7D" tube outline. 6.3 volt filament.
::Thanks,
::Dave
4/24/2010 10:36:47 PMDave Froehlich
Norm,
Thanks very much for the tube. The old one had a very loose envelope. It turned out that the tube wasn't the problem after all. I took out the chassis and checked everything and the large power resistor was touching something it wasn't supposed to. I moved it out of the way and "like magic" the radio was working. I must have accidentally moved it when I was replacing the capacitors.
Thanks Again,
:Dave
: If you want a 6B7 send an email.
::Hello Again All,
:: It's a 6B8 that could be adapted to a 6B7 socket. I might have one of those.
::Thanks,
::Dave
:::Hello All,
::: I don't have a 6B7 for my radio. But I can probably make an adaptor. But What tube is most like a 6B7?
:::"Twin Diode - Remote Cutoff Pentode" That's a "7D" tube outline. 6.3 volt filament.
:::Thanks,
:::Dave
4/25/2010 9:13:26 AMNorm Leal
Good to hear you have the radio working. Now you have a spare 6B7. Might need it in the future.
:Norm,
: Thanks very much for the tube. The old one had a very loose envelope. It turned out that the tube wasn't the problem after all. I took out the chassis and checked everything and the large power resistor was touching something it wasn't supposed to. I moved it out of the way and "like magic" the radio was working. I must have accidentally moved it when I was replacing the capacitors.
:Thanks Again,
:Dave
::Dave
:: If you want a 6B7 send an email.
:::Hello Again All,
::: It's a 6B8 that could be adapted to a 6B7 socket. I might have one of those.
:::Thanks,
:::Dave
::::Hello All,
:::: I don't have a 6B7 for my radio. But I can probably make an adaptor. But What tube is most like a 6B7?
::::"Twin Diode - Remote Cutoff Pentode" That's a "7D" tube outline. 6.3 volt filament.
::::Thanks,
::::Dave
4/25/2010 10:45:16 AMDoug Criner
If the glass envelope is loose at the base, you can dabble a small amount of super glue around the joint.
4/30/2010 2:21:04 PMDave Froehlich
Doug,
I have tried all sorts of "Super Glue" and "crazy glue" and it has never worked for me. I don't find that it can hold anything together at all. It always falls apart. Plus, it has a very strong odor. I've tried that on tubes and it never holds. I have also tried tape and that doesn't work either. So I'm going to keep the tube as it is. I think that the original glue was much different. If I had that glue I think I could get it to work. But what kind of glue was it?
:If the glass envelope is loose at the base, you can dabble a small amount of super glue around the joint.
5/1/2010 9:09:26 PMjim l
Dave, why not give JB Weld a try. I use it and holds for me. Also have used a glue gun but if tube gets very hot may not work
:Thanks,
:Dave
::If the glass envelope is loose at the base, you can dabble a small amount of super glue around the joint.
