4/18/2010 12:01:49 PMScott(85653:0)
Anybody know if JB Weld is conductive?
4/18/2010 3:38:52 PMGeorge T(85659:85653)
Hi, I don't think it is but you could always lay out a thin line of it and check the ohm's reading with your meter. It is like an Epoxy. Good Luck, George T.
4/19/2010 9:07:08 PMSage(85676:85659)
The resin component contains 10 - 20% iron powder by weight. The iron powder is apparently well-encapulated during the curing process. I don't think it will be very conductive at low voltages but suspect it could become quite conductive at higher voltages - ie., in the KV range.....
4/20/2010 6:40:58 AMScott(85681:85676)
Thanks gentlemen. This should work for my application.
