Antenna Plug
4/9/2010 10:36:06 AMScott
Curious about this plug. Mounted on a stewart warner and wired into the antenna coil and chassis. How were these originally used?
4/9/2010 10:48:17 AMNorm Leal
Hi Scott
Some homes made in the 1930's had built in antenna and ground. Antennas were usually run into the attic and ground may be to a water pipe.
Radios had two connectors that plugged into the wall. One for AC power and the other antenna/ground.
:Curious about this plug. Mounted on a stewart warner and wired into the antenna coil and chassis. How were these originally used?
4/9/2010 11:46:56 AMPeter G. Balazsy
Wow Norm!
... you're a wealth of great info.
. I had no clue.
But I can see how it seemed like a good idea.. though short lived.
4/9/2010 4:34:44 PMScott
Thanks Norm.....guess I am going to have to move!
