Something shorted on the B+ line. Use a variac and set voltage lower so don't get smoke. Doesn't matter if tubes light for testing. Do you have any B+ voltage?
Most likely a cap on the B+ line is shorted.
:Hello All,
: I replaced the monster sized diode someone replaced the original selenium diode with, and replaced that with a 1N400x and a 100 ohm resistor in series with that. When I turn it on, there is a waft of smoke, but I cannot see where that's coming from because I shut off the set as soon as I see the smoke. The smoke stops almost instantly when the power is off. There is obviously no B+ due to a really heavy load somewhere. The filament string works fine though.
: If anyone has suggestions what to look at, please let me know. Otherwise, I'll search until I find it. Someone "restored" this set before I received it. So there could be some wiring mistakes as well.
:Thanks,
:Dave
:Hi Dave
: Something shorted on the B+ line. Use a variac and set voltage lower so don't get smoke. Doesn't matter if tubes light for testing. Do you have any B+ voltage?
: Most likely a cap on the B+ line is shorted.
::Hello All,
:: I replaced the monster sized diode someone replaced the original selenium diode with, and replaced that with a 1N400x and a 100 ohm resistor in series with that. When I turn it on, there is a waft of smoke, but I cannot see where that's coming from because I shut off the set as soon as I see the smoke. The smoke stops almost instantly when the power is off. There is obviously no B+ due to a really heavy load somewhere. The filament string works fine though.
:: If anyone has suggestions what to look at, please let me know. Otherwise, I'll search until I find it. Someone "restored" this set before I received it. So there could be some wiring mistakes as well.
::Thanks,
::Dave
:Hi Dave
::Hello All,
::Thanks,
::Dave
:Hello All,
:Thanks,
:Dave
