Very little difference. 6SN7GTA and GTB have some improvements. Controlled warm up for use in series wired filament TV's (GTB) and higher ratings for Vertical Deflection Amplifiers in TV (GTA & GTB). The 6SN7GT was used in the same circuit prior to the inprovements.
:Hello , I'm wondering since I can't find an explaination on-line and don't have any tube manuals . What is the difference between 6sn7 gtb, gta , gt and so on ? I just won two NOS 6sn7gtb's on that popular aution website. I think I got lucky because these things are getting expensive. Many thanks
You can always go higher (B instead of A) but I would not go backward, especially in a series filament TV.
::Hello , I'm wondering since I can't find an explaination on-line and don't have any tube manuals . What is the difference between 6sn7 gtb, gta , gt and so on ? I just won two NOS 6sn7gtb's on that popular aution website. I think I got lucky because these things are getting expensive. Many thanks
Best Regards,
Bill Grimm
Best Regards,
Bill Grimm
:And, speaking of 7 watts, one is used as a push-pull output on one of my Webster Chicago wire recorders. It certainly adds a lot to the fidelity of the machine (what fidelity a wire recorder can have), and has quite a bit of power reserve.
:T.
Not as common as TV's but they were used in some radios and audio amps. Usually as audio amplifiers and phase inverters to drive push pull.
:Hi Thomas,
: This is the first time I have heard of 6SN7GT used in something other than a television. Were they ever used in radios?
:Best Regards,
:Bill Grimm
::And, speaking of 7 watts, one is used as a push-pull output on one of my Webster Chicago wire recorders. It certainly adds a lot to the fidelity of the machine (what fidelity a wire recorder can have), and has quite a bit of power reserve.
::T.
My 1949 Zenith FoMoCo (Mercury) radio uses a 6SN7 as a phase inverter for the audio. I have also seen them used in guitar amplifiers.
Best Regards,
Bill Grimm
http://www.audiotubes.com/6sn7.htm
Here's sort of the idea, but I'd hope to scotch the solid-state output and go straight from the 2nd 12SN7 stage as the audio output.
