BSR Record Player - Needles
3/29/2010 12:53:20 PMJoe
I have what I believe is a BSR UA-15 Record Player. What is the proper proceedure to replace the needles? It has a flip Astatic 422 cartridge with two needles - a "N8-3" (78 rpm) needle and a "N8-1" (LP) needle. Also, does anyone know where I might get a SAMS Photofact on this player?
3/29/2010 7:51:57 PMBill VA
Joe, N8-3 and N8-1 are held in place with a screw. To remove needle, unscrew the screw. Is this what you mean? Also, go to SAMS Photofact and search UA15 and you will see more than one SAMS that applies to the UA-15 series. I think most UA15 changers indicate the complete model number.
:I have what I believe is a BSR UA-15 Record Player. What is the proper proceedure to replace the needles? It has a flip Astatic 422 cartridge with two needles - a "N8-3" (78 rpm) needle and a "N8-1" (LP) needle. Also, does anyone know where I might get a SAMS Photofact on this player?
3/30/2010 7:05:31 AMJoe
Hi Bill,
Thanks for responding. I don't see a screw that holds the needle to the cartridge as you sugguested. I'm going to try to send an image.
It looks like the needle is held behind that red plastic nub. Do you think the needle is held in by friction and will slide on and off?
Joe
3/30/2010 8:57:01 AMBill VA
Ok, the retainer. Needle comes off by pulling with finger or tool of your choice toward tone arm front. Reverse for replacement.
Bill
:Hi Bill,
:Thanks for responding. I don't see a screw that holds the needle to the cartridge as you sugguested. I'm going to try to send an image.
:It looks like the needle is held behind that red plastic nub. Do you think the needle is held in by friction and will slide on and off?
:Joe
3/30/2010 10:29:11 AMJoe
Bill,
Thanks, you've been a great help.
Joe
4/7/2010 12:53:59 PMEdd
Sir Joe. . . . . .
Since you did not make your Email addee "hot" in your initial posting forms preamble, I was not exactly certain if we had dos Joses present last month.
I do have 8 pages . .a . .la . .Pee Dee Eff . . . of adjustments, parts list and mechanical structuring blow ups of that BSR U-15 series Changer / Turntable, if you want such to be forwarded to you.
Or any one else . . just provide me a hot addee.
:Bill,
:Thanks, you've been a great help.
:Joe
