:Hi all ...I recently picked up some 25,000 ohm @ 50 watt porcelin resistors. They have a moveable adjuster on them. I usually use these in my early A.C. sets. The problem is I usually need more than one adjustor. I tried to make more with a strip of meatal and a small nut/bolt to tighten ..but does not work all that great...ANY SUGGESTIONS?
Nice idea. Just because a 25,000 ohm resistor is rated 50 watts doesn't mean a small portion can carry more current. Each portion of the resistor is limited in current as to what the overall resistor can carry.
:Shine the wires in the area of contact w/fine sand paper.
:marv
::Hi all ...I recently picked up some 25,000 ohm @ 50 watt porcelin resistors. They have a moveable adjuster on them. I usually use these in my early A.C. sets. The problem is I usually need more than one adjustor. I tried to make more with a strip of meatal and a small nut/bolt to tighten ..but does not work all that great...ANY SUGGESTIONS?
:Hi
: Nice idea. Just because a 25,000 ohm resistor is rated 50 watts doesn't mean a small portion can carry more current. Each portion of the resistor is limited in current as to what the overall resistor can carry.
: Norm
::Shine the wires in the area of contact w/fine sand paper.
::marv
:::Hi all ...I recently picked up some 25,000 ohm @ 50 watt porcelin resistors. They have a moveable adjuster on them. I usually use these in my early A.C. sets. The problem is I usually need more than one adjustor. I tried to make more with a strip of meatal and a small nut/bolt to tighten ..but does not work all that great...ANY SUGGESTIONS?
What you are doing is fine just current is a small section can't be higher than resistor overall rating.
To keep numbers round I will use 40 ma max for your resistor. 25000 x .04 = 1000 volts. 1000 x .04 = 40 watts Use one section of 5000 ohms current is still limited to 40 ma. 5000 x .04 = 200 volts 200 x .04 = 8 watts. A 5000 ohm section off a resistor like this would be limited to 8 watts.
You can get a little more due to heat sinking but resistor wire size will limit each section.
:Soooo Norm...are you saying that what I am doing is not a good idea or is ok?... What I am doing is using these resistors for "block" sections...say 2000 ohms and 5000 ohms....Or I need a resistor at 5000 ohms at 15 watts. What I did is I took my Dremmel tool cut resistor in half...and made a adjuster so between the two lugs I have 5000 ohms.
::Hi
:: Nice idea. Just because a 25,000 ohm resistor is rated 50 watts doesn't mean a small portion can carry more current. Each portion of the resistor is limited in current as to what the overall resistor can carry.
:: Norm
:::Shine the wires in the area of contact w/fine sand paper.
:::marv
::::Hi all ...I recently picked up some 25,000 ohm @ 50 watt porcelin resistors. They have a moveable adjuster on them. I usually use these in my early A.C. sets. The problem is I usually need more than one adjustor. I tried to make more with a strip of meatal and a small nut/bolt to tighten ..but does not work all that great...ANY SUGGESTIONS?
Nothing wrong with using sections as long as current isn't exceeded. Can't go by watttage alone. As you go lower in resistance wattage will also be reduced. A section of resistor measuring 500 ohms can only dissipate .8 watts using 40 ma for the resistor.
500 ohms x .04 amps = 20 volts
20 volts x .04 amps = .8 watts
You have a good idea especially when a specific resistor value isn't available.
::George
:: What you are doing is fine just current is a small section can't be higher than resistor overall rating.
:: To keep numbers round I will use 40 ma max for your resistor. 25000 x .04 = 1000 volts. 1000 x .04 = 40 watts Use one section of 5000 ohms current is still limited to 40 ma. 5000 x .04 = 200 volts 200 x .04 = 8 watts. A 5000 ohm section off a resistor like this would be limited to 8 watts.
:: You can get a little more due to heat sinking but resistor wire size will limit each section.
:: Norm
:::Soooo Norm...are you saying that what I am doing is not a good idea or is ok?... What I am doing is using these resistors for "block" sections...say 2000 ohms and 5000 ohms....Or I need a resistor at 5000 ohms at 15 watts. What I did is I took my Dremmel tool cut resistor in half...and made a adjuster so between the two lugs I have 5000 ohms.
::::Hi
:::: Nice idea. Just because a 25,000 ohm resistor is rated 50 watts doesn't mean a small portion can carry more current. Each portion of the resistor is limited in current as to what the overall resistor can carry.
:::: Norm
:::::Shine the wires in the area of contact w/fine sand paper.
:::::marv
::::::Hi all ...I recently picked up some 25,000 ohm @ 50 watt porcelin resistors. They have a moveable adjuster on them. I usually use these in my early A.C. sets. The problem is I usually need more than one adjustor. I tried to make more with a strip of meatal and a small nut/bolt to tighten ..but does not work all that great...ANY SUGGESTIONS?
