electrolytic cap replacement
3/24/2010 11:31:57 PMneondave
On the ol' metal can caps,..with one threaded stud on the bottom,..this is prob the + terminal of this cap ? This is on a Philco 80 Jr.
I dont wanna goof this up, and, even though I have the schematic, im not good at reading them
Thanks much!,dave
3/24/2010 11:36:15 PMTerry Decker
:On the ol' metal can caps,..with one threaded stud on the bottom,..this is prob the + terminal of this cap ? This is on a Philco 80 Jr.
: I dont wanna goof this up, and, even though I have the schematic, im not good at reading them
: Thanks much!,dave
The part that touches the chassis is the negative. There should be SOME kind of marking on the case.
terry
3/25/2010 10:30:03 AMNorm Leal
Hi Dave
You may want to check this schematic:
http://www.nostalgiaair.org/PagesByModel/843/M0013843.pdf
The cap end where part number points is positive in this schematic. Although chassis is negative electrolytics will be insulated since two negatives connect to high voltage center tap on the transformer.
::On the ol' metal can caps,..with one threaded stud on the bottom,..this is prob the + terminal of this cap ? This is on a Philco 80 Jr.
:: I dont wanna goof this up, and, even though I have the schematic, im not good at reading them
:: Thanks much!,dave
:The part that touches the chassis is the negative. There should be SOME kind of marking on the case.
:terry
3/25/2010 9:33:43 PMneondave
ok, maybe i should ask, on a meteal can cap,...the can is neg ?
This radio only has two caps on top of chassis,..and are insulated from the chassis,...although both tie to a common connection, which , i think should be the ( - ) neg. ?,
I can pick out componants in a schematic,..but when tracing connections,..i suck :-(
Thanks!,dave
:Hi Dave
: You may want to check this schematic:
:http://www.nostalgiaair.org/PagesByModel/843/M0013843.pdf
: The cap end where part number points is positive in this schematic. Although chassis is negative electrolytics will be insulated since two negatives connect to high voltage center tap on the transformer.
:::On the ol' metal can caps,..with one threaded stud on the bottom,..this is prob the + terminal of this cap ? This is on a Philco 80 Jr.
::: I dont wanna goof this up, and, even though I have the schematic, im not good at reading them
::: Thanks much!,dave
::The part that touches the chassis is the negative. There should be SOME kind of marking on the case.
::terry
3/25/2010 10:09:22 PMBrett
The can is negative. The center terminal on the bottom is insulated from the can and is positive.
3/25/2010 11:20:54 PMneondave
:The can is negative. The center terminal on the bottom is insulated from the can and is positive.
Thanks !!!!!
3/25/2010 11:59:27 PMplanigan
Neondave, the last post is correct. The can is always the negtive terminal of the electrolytic caps. Heed what Norm said, while it is the negative lead of the cap, the can is frequently isolated from the chassis ground and goes to the center tap (B-) of the HV winding of the transformer through resistor(s) as is done in your set. PL
::The can is negative. The center terminal on the bottom is insulated from the can and is positive.
: Thanks !!!!!
3/26/2010 1:43:46 PMsteveb
I just completed one of these. The center is the positive as stated before and the terminal on the side (can) is insulated from the chassis and is the B-
Put the (-) end of the cap there.
:Neondave, the last post is correct. The can is always the negtive terminal of the electrolytic caps. Heed what Norm said, while it is the negative lead of the cap, the can is frequently isolated from the chassis ground and goes to the center tap (B-) of the HV winding of the transformer through resistor(s) as is done in your set. PL
:::The can is negative. The center terminal on the bottom is insulated from the can and is positive.
:: Thanks !!!!!
3/26/2010 10:43:31 PMneondave
:I just completed one of these.....
Yea, i just picked this up a month ago,..the guy i bought it from said when he was a trash truck driver,and an old man asked if he wanted it,..if not, in da dumpster it goes. He was told it didnt work, a bad tube. So now i got it. All the tube heaters tested good,..so i slowly powered up with a variac and a 60w light bulb. The dang thing worked !, so, i thought id at least replace the two filter caps, the cab isnt the greatist,..its all there, but the lamination plys on the curved part are all seperating,...maybe i could glue and clamp ? or just leave it be....got any spare parts for this ?? the power switch is a little a little finicky,..maybe another reason they thought tubes were bad....
