You could try Digi-Key, digikey.com. Two electrolytics, in series, back to back will work. It's best to put a diode across each.
Using a capacitor does have some problems. The capacitors will stay cool but turn on surge will be hard on filaments and lamps. You will need zener diodes across any lamps in your radio.
: I need a 7-10 microfarad non-polarized capacitor @100vac or greater to replace a resistance line cord. Does anyone know where I can find one (or more)?
: Hi Joe
: You could try Digi-Key, digikey.com. Two electrolytics, in series, back to back will work. It's best to put a diode across each.
: Using a capacitor does have some problems. The capacitors will stay cool but turn on surge will be hard on filaments and lamps. You will need zener diodes across any lamps in your radio.
: Norm
: : I need a 7-10 microfarad non-polarized capacitor @100vac or greater to replace a resistance line cord. Does anyone know where I can find one (or more)?
1. If using two electrolytics back to back would you, say, connect minus to minus and then the pluses in series with the circuit to be dropped? I would think you could do it the other way too, connecting the pluses together.
2. How do you orient the diodes (cathode towards what) across the caps?
3. Could you eliminate the turn-on surge by also putting a surge protector or thermistor in series with the caps? Would that eliminate the need for zener diode?
Reece
: Hi Joe
: Norm
