I think this radio uses the two 45 volt batteries in series to supply both 45 volts and 90 volts to the radio. The red wire may give the 90 volt B+ plate voltages, white 45 volts B+ and the black B-. The brown appears to be filament - for the audio transformer from the A- battery terminal.
What I would do is pull all of the tubes and hook it up that way. Then check with a meter those voltages that can be checked that way against the specifications. If ok then try some tubes.
Ed.
If you are unsure hook up the A battery first. See if filaments glow. The room needs to be dark to notice filaments.
This will show that A and B battery leads aren't mixed up. You wouldn't want 90 volts connected to filaments.
:It is difficult to say definitly as the cable, the switch and faded wires can confuse things.
:I think this radio uses the two 45 volt batteries in series to supply both 45 volts and 90 volts to the radio. The red wire may give the 90 volt B+ plate voltages, white 45 volts B+ and the black B-. The brown appears to be filament - for the audio transformer from the A- battery terminal.
:What I would do is pull all of the tubes and hook it up that way. Then check with a meter those voltages that can be checked that way against the specifications. If ok then try some tubes.
:Ed.
:Brian
: If you are unsure hook up the A battery first. See if filaments glow. The room needs to be dark to notice filaments.
: This will show that A and B battery leads aren't mixed up. You wouldn't want 90 volts connected to filaments.
::It is difficult to say definitly as the cable, the switch and faded wires can confuse things.
::I think this radio uses the two 45 volt batteries in series to supply both 45 volts and 90 volts to the radio. The red wire may give the 90 volt B+ plate voltages, white 45 volts B+ and the black B-. The brown appears to be filament - for the audio transformer from the A- battery terminal.
::What I would do is pull all of the tubes and hook it up that way. Then check with a meter those voltages that can be checked that way against the specifications. If ok then try some tubes.
::Ed.
