3/4/2010 12:36:25 PMPaul(84613:0)
The tuning shaft that extends through the hole in the case on my newly acquired 6-S-128 wobbles back and forth. I can actually press down or sideways on it and it will not only move in that direction, but the sound (signal) will cut out when I do. If I gently turn it it's smooth as silk, but wobbles when I more quickly tune. Before I go ripping into the set, can someone tell me if this is normal or something has come loose during shipping? Thanks.
3/4/2010 1:39:15 PMWarren(84615:84613)
Think the nut that holds the shaft is loose. It's touching a component shorting it out. Don't play it like that till you tighten the nut.
3/4/2010 4:01:02 PMPaul(84619:84615)
:Think the nut that holds the shaft is loose. It's touching a component shorting it out. Don't play it like that till you tighten the nut.
3/4/2010 4:38:27 PMWarren(84623:84619)
The speaker un-plugs, remove the knobs. chassis screws on the bottom. Slide the chassis out with care. I don't think you will need to mess with the dial, sounds like just a loose nut on the shaft below the dial. Should be an easy fix.
3/5/2010 8:27:03 AMBill G.(84640:84619)
Hi Paul,
Warren seems to be giving you good advice. I want to add that you may need to take steps to keep the nut from loosening again. Lock-tight or a locking washer may be possibilities.
Best Regards,
Bill Grimm
3/8/2010 1:16:41 PMPaul(84704:84640)
:Hi Paul,
: Warren seems to be giving you good advice. I want to add that you may need to take steps to keep the nut from loosening again. Lock-tight or a locking washer may be possibilities.
:Best Regards,
:Bill Grimm
