Radiola III schematics
3/3/2010 11:00:44 PMBob
Just started playing with a few old radios for about 6 years now which makes me a novice. Never paid much attention to the schematics of the old Radiola III's. The other day was looking at it and I think there is a mistake on the interstage transformer. The diagram shows a capacitor, er, condenser connected across the transformer, after checking both of my Radiola III's this is in error, or am I wrong? Also the metal tabs on the wires one of them says -C 1 1/2 volts. Should not this be -4 1/2 volts.
3/4/2010 3:47:03 AMWarren
Don't know for sure. But this may be a clue about that.
http://www.radiolaguy.com/Showcase/RadiolaIII.htm
3/4/2010 10:13:31 AMNorm Leal
Hi Bob
The cap you mention is a metal strip mounted right at interstage transformer terminals. Doesn't look much like a cap.
C voltage depends on B+ voltage. Since this radio calls out 40 volts for B+ a C- voltage of 1 1/2 would be enough. If you use higher B+ increase negative C voltage.
http://www.nostalgiaair.org/PagesByModel/349/M0040349.pdf
:Just started playing with a few old radios for about 6 years now which makes me a novice. Never paid much attention to the schematics of the old Radiola III's. The other day was looking at it and I think there is a mistake on the interstage transformer. The diagram shows a capacitor, er, condenser connected across the transformer, after checking both of my Radiola III's this is in error, or am I wrong? Also the metal tabs on the wires one of them says -C 1 1/2 volts. Should not this be -4 1/2 volts.
3/4/2010 4:16:00 PMBob
:Hi Bob
: The cap you mention is a metal strip mounted right at interstage transformer terminals. Doesn't look much like a cap.
: C voltage depends on B+ voltage. Since this radio calls out 40 volts for B+ a C- voltage of 1 1/2 would be enough. If you use higher B+ increase negative C voltage.
:http://www.nostalgiaair.org/PagesByModel/349/M0040349.pdf
::Just started playing with a few old radios for about 6 years now which makes me a novice. Never paid much attention to the schematics of the old Radiola III's. The other day was looking at it and I think there is a mistake on the interstage transformer. The diagram shows a capacitor, er, condenser connected across the transformer, after checking both of my Radiola III's this is in error, or am I wrong? Also the metal tabs on the wires one of them says -C 1 1/2 volts. Should not this be -4 1/2 volts.
3/4/2010 4:16:43 PMBob
:Hi Bob
