:Hello All,
: I have two of these and decided to electronically restore them. One works very well. The other has weak volume. Now either I made a mistake restoring it or there is something that's not working correctly. I have the service data in the RCA Red Book that starts on Page 8-B. I should be able to find this. There's not much to this radio. But if someone has some ideas where to look, I would appriciate it. I checked the resistors (not very much drift), I haven't tested the tubes yet. The 1-v aka. 6Z3 had no emission, so I'm borrowing the one from the working chassis. How unusual is it to have two RCA 4Ts in the same place at the same time? Is this a rare set or are there many of them still around?
:Thanks,
:Dave
:Hello Dave,
:I have an RCA 4T that I restored about three years ago. This might not apply to your situation, but I have a vague recollection that there was a "low resistance short" between the chassis and a wire that was connected to a terminal mounted on the chassis (inside back). This was causing the volume to be very low (almost zero)and it immediately corrected when I adjusted the wire to remove the short. I recalled that at the time I thought that the layout was very susceptible to causing this "shorting issue" Sorry, I don't remember what specific wire was involved. So, you might want to carefully examine the wiring to see that there are no "shorting issues" on the radio with low volume. Dale
::Hello All,
:: I have two of these and decided to electronically restore them. One works very well. The other has weak volume. Now either I made a mistake restoring it or there is something that's not working correctly. I have the service data in the RCA Red Book that starts on Page 8-B. I should be able to find this. There's not much to this radio. But if someone has some ideas where to look, I would appriciate it. I checked the resistors (not very much drift), I haven't tested the tubes yet. The 1-v aka. 6Z3 had no emission, so I'm borrowing the one from the working chassis. How unusual is it to have two RCA 4Ts in the same place at the same time? Is this a rare set or are there many of them still around?
::Thanks,
::Dave
:Hello Dave,
::Hello All,
::Thanks,
::Dave
I think you could replace the missing knobs with generics from RadioDaze or Antique Radio Supply - and the set would still look nice.
:Is this a rare set or are there many of them still around?
:Dave
:No, it's not particularly rare - nice cathedral, 1935 model. Slusser has the value $140-150 for a complete set in decent shape, with knobs. That price might be a bit optimistic in today's market.
:I think you could replace the missing knobs with generics from RadioDaze or Antique Radio Supply - and the set would still look nice.
::Is this a rare set or are there many of them still around?
::Dave
::Dave
::Dave
I have a few of the walnut-colored, wooden, generic knobs I was thinking of. They are 1-1/8" diameter, round, with a set-screw, and for a 1/4" shaft. There is no index marker, but you could paint a small dot, as required. They are not reproductions of the original 4T knobs, but may look OK, at least to an uniformed eye. I seem to recall that the 4T original knobs were dark plastic, not wooden.
If you can't find originals or reproductions of the originals, contact me, and I'll help you out.
:Doug,
: I just looked at all of Radiodaze's knobs on their website and I can't find them there either. Where did you see them?
:Hmmm - they used to have them, but I couldn't find them either. Strange.
:I have a few of the walnut-colored, wooden, generic knobs I was thinking of. They are 1-1/8" diameter, round, with a set-screw, and for a 1/4" shaft. There is no index marker, but you could paint a small dot, as required. They are not reproductions of the original 4T knobs, but may look OK, at least to an uniformed eye. I seem to recall that the 4T original knobs were dark plastic, not wooden.
:If you can't find originals or reproductions of the originals, contact me, and I'll help you out.
::Doug,
:: I just looked at all of Radiodaze's knobs on their website and I can't find them there either. Where did you see them?
