GE J-64 low end of AM fades out
3/1/2010 2:59:47 PMDan Lejnieks
I have a J-64 that I have recapped and has been working well for a couple of years. Now, however, if I am listening to stations lower than 1200kc the station eventually fades and the radio is quiet. If I turn the radio to a frequency higher than 1200 it makes noise again until I tune it down again - then it eventually cuts out. I am guessing it is the oscillator even though the tube tests good on my tester. I am going to try replacing it unless someone here can point me in another direction. Thanx for any help.
Dan Lejnieks
3/1/2010 3:30:26 PMWarren
It does sound like the 6SA7 is the problem. A lot of those seem to develop shorts. If you tap on the tube, it may clear for awhile.
3/1/2010 10:16:59 PMThomas Dermody
Gassy? Gassy tubes can test good, but often malfunction as oscillators, since the tube's function will be affected by the ionization of the gas.
Could also be a drifted resistor either feeding power to the oscillator circuit, or in the oscillator circuit itself.
3/2/2010 1:42:24 AMDan Lejnieks
Thanks!!
I have some new tubes coming. I will let everyone know what happens.
Dan
3/10/2010 1:04:45 PMDan L.
Changed the 6SA7 and now everything is working again. Thanks everyone!
Dan
