If you have a 'scope, look at the waveform between the two test probes. It should be a pulsating, rectified wave. What's the peak?
:What ac voltage do you measure at the xfmr's high-voltage secondary winding? It will depend on the winding ratio.
:If you have a 'scope, look at the waveform between the two test probes. It should be a pulsating, rectified wave. What's the peak?
When rejuvenating '01As (which have thoriated cathodes), I typically run the filaments for several hours above 6.3V.
:And if a big enough zap you can conclude the cap is good?
:Bill
When I am in a rush, I just connect a HV source of the suspect component's rating through a 10 K resistor and dc milliamp meter in parallel, and watch the current consumption.
In the end, it is probably more cost effective, (if your time is worth more than half the minimum wage to just replace the capacitor.
But then again, if you are going to disguise your repair, you will spend a lot of time sawing or melting out the old innerds and stuffing with new components.
Up to you.
:Yes, and with experience you can estimate the cap's value, uF.
::And if a big enough zap you can conclude the cap is good?
::Bill
You can get an idea of capacity by dumping the charge into a meter with series resistor. The higher a meter reads and longer it hold the more capacity. Need to try it to see the response.
:Good point. If an old filter cap can hold enough of a charge for an hour or so, it's probably usable. I use an ancient Eico 950 B to test and reform equally ancient capacitors, and you get a good sense of whether you have a lost cause or not after a few minutes. With patience, it might take a couple of hours or more to reform a really old specimen.
:When I am in a rush, I just connect a HV source of the suspect component's rating through a 10 K resistor and dc milliamp meter in parallel, and watch the current consumption.
:In the end, it is probably more cost effective, (if your time is worth more than half the minimum wage to just replace the capacitor.
:But then again, if you are going to disguise your repair, you will spend a lot of time sawing or melting out the old innerds and stuffing with new components.
:Up to you.
::Yes, and with experience you can estimate the cap's value, uF.
:::And if a big enough zap you can conclude the cap is good?
:::Bill
