philco model 6d525 speaker
2/21/2010 10:58:46 PMrobert
I'm working on a Philco 6d525 and know I am looking for or some way of repairing the speaker cone. About half of the cone is gone. Can you recone or get a repair kit for the little 4 inch speaker?
2/21/2010 11:09:28 PMrobert
:I'm working on a Zenith 6d525 and know I am looking for or some way of repairing the speaker cone. About half of the cone is gone. Can you recone or get a repair kit for the little 4 inch speaker?
:Sorry about the philco. It is a Zenith.
There is no edit feature on the forum.
2/22/2010 11:46:01 AMNorm Leal
Hi
You could repair the cone youself with glue and a little paper.
Others can do it for you but that's costly.
Could use a modern 4" speaker which are common but won't have a field coil. The field coil could be used from your original or a resistor used in its place.
Check here to see what's available:
http://www.oldradioparts.com/2a32fl.txt
::I'm working on a Zenith 6d525 and know I am looking for or some way of repairing the speaker cone. About half of the cone is gone. Can you recone or get a repair kit for the little 4 inch speaker?
::Sorry about the philco. It is a Zenith.
:There is no edit feature on the forum.
2/22/2010 12:59:16 PMRobert
:Hi
: You could repair the cone youself with glue and a little paper.
: Others can do it for you but that's costly.
: Could use a modern 4" speaker which are common but won't have a field coil. The field coil could be used from your original or a resistor used in its place.
: Check here to see what's available:
:http://www.oldradioparts.com/2a32fl.txt
:::I'm working on a Zenith 6d525 and know I am looking for or some way of repairing the speaker cone. About half of the cone is gone. Can you recone or get a repair kit for the little 4 inch speaker?
:::Sorry about the philco. It is a Zenith.
::There is no edit feature on the forum.
::Thanks for the reply Norm :)
Is there an article on changing on changing the radio from a field coil to a pm speaker?
Bob.
2/22/2010 1:53:50 PMNorm Leal
Bob
Here is what you can do. Replace the field coil with a resistor of the same or slightly larger value. Use a 10 watt rresistor. It will operate warm. If this gives too much hum increase filter cap values.
6D525 uses two 20 mf @ 150 volt filter caps. Use up to 47 mf if necessary. This value was used in other radios which didn't have field coils.
::Hi
:: You could repair the cone youself with glue and a little paper.
:: Others can do it for you but that's costly.
:: Could use a modern 4" speaker which are common but won't have a field coil. The field coil could be used from your original or a resistor used in its place.
:: Check here to see what's available:
::http://www.oldradioparts.com/2a32fl.txt
::::I'm working on a Zenith 6d525 and know I am looking for or some way of repairing the speaker cone. About half of the cone is gone. Can you recone or get a repair kit for the little 4 inch speaker?
::::Sorry about the philco. It is a Zenith.
:::There is no edit feature on the forum.
:::Thanks for the reply Norm :)
:Is there an article on changing on changing the radio from a field coil to a pm speaker?
:Bob.
2/22/2010 11:47:52 PMrobert
:Bob
:Thanks so much for the info. Would the resistor mod remove any value from the radio?
bob.
: Here is what you can do. Replace the field coil with a resistor of the same or slightly larger value. Use a 10 watt rresistor. It will operate warm. If this gives too much hum increase filter cap values.
: 6D525 uses two 20 mf @ 150 volt filter caps. Use up to 47 mf if necessary. This value was used in other radios which didn't have field coils.
:::Hi
::: You could repair the cone youself with glue and a little paper.
::: Others can do it for you but that's costly.
::: Could use a modern 4" speaker which are common but won't have a field coil. The field coil could be used from your original or a resistor used in its place.
::: Check here to see what's available:
:::http://www.oldradioparts.com/2a32fl.txt
:::::I'm working on a Zenith 6d525 and know I am looking for or some way of repairing the speaker cone. About half of the cone is gone. Can you recone or get a repair kit for the little 4 inch speaker?
:::::Sorry about the philco. It is a Zenith.
::::There is no edit feature on the forum.
::::Thanks for the reply Norm :)
::Is there an article on changing on changing the radio from a field coil to a pm speaker?
::Bob.
