IT works grea, except the lower frequency am won't work well.
During alignment @ 1500 There is -5 dc at the junction of c37, L12, and r17. When aligning lower end (600) it reads ~1.7 volts. I can get it to decrease but not increase. When the screwdriver is on the trimmer screw of the padder, The voltage goes up to over 2.5 volts. I noticed that this trimmer is Physically backwards to all of the others, could this do it?
WJR barely comes in, where as a station at 1200 is booming.
Im going to test some voltages and keep trying, I will be awake for some time yet.
Ian
This radio has padder caps identified as C11, 12 and 13. These adjustments are used to peak up the low end of bands.
Adjust the padder while rocking tuning back and forth, listening to low end of the dial. Set for the loudest signal.
Oscillator voltage will change as you tune across the dial. This is normal and won't have an effect on operatrion as long as the osc keeps operating.
:Hi, Im working on my Sparton 1568
:http://www.nostalgiaair.org/PagesByModel/687/M0018687.pdf
:IT works grea, except the lower frequency am won't work well.
:During alignment @ 1500 There is -5 dc at the junction of c37, L12, and r17. When aligning lower end (600) it reads ~1.7 volts. I can get it to decrease but not increase. When the screwdriver is on the trimmer screw of the padder, The voltage goes up to over 2.5 volts. I noticed that this trimmer is Physically backwards to all of the others, could this do it?
:WJR barely comes in, where as a station at 1200 is booming.
:Im going to test some voltages and keep trying, I will be awake for some time yet.
:Ian
:Hi Ian
: This radio has padder caps identified as C11, 12 and 13. These adjustments are used to peak up the low end of bands.
: Adjust the padder while rocking tuning back and forth, listening to low end of the dial. Set for the loudest signal.
: Oscillator voltage will change as you tune across the dial. This is normal and won't have an effect on operatrion as long as the osc keeps operating.
::Hi, Im working on my Sparton 1568
::http://www.nostalgiaair.org/PagesByModel/687/M0018687.pdf
::IT works grea, except the lower frequency am won't work well.
::During alignment @ 1500 There is -5 dc at the junction of c37, L12, and r17. When aligning lower end (600) it reads ~1.7 volts. I can get it to decrease but not increase. When the screwdriver is on the trimmer screw of the padder, The voltage goes up to over 2.5 volts. I noticed that this trimmer is Physically backwards to all of the others, could this do it?
::WJR barely comes in, where as a station at 1200 is booming.
::Im going to test some voltages and keep trying, I will be awake for some time yet.
::Ian
Don't use the padder to peak this voltage. Tune to the lowest station you receive and adjust padder for max volume while rocking tuning back and forth. The signal will come up.
Wire wound or carbon resistors won't be a problem on the B+ line. You don't have to worry about inductance as there will be caps to ground on both sides of a resistor.
:When the padder C11 is screwed trightly the voltage goes up to about half of what the high end (1500) yields. I get NO staions below 1000 except WJR , but it is very faint. The eye tube doesnt move on lower stations , including the signal from the generator,
:The B+ was very high, I dropped it down with a large resistor, the bass decreased dramatically. Is this becasuse it is a wirewound resistor?
:Ian
::Hi Ian
:: This radio has padder caps identified as C11, 12 and 13. These adjustments are used to peak up the low end of bands.
:: Adjust the padder while rocking tuning back and forth, listening to low end of the dial. Set for the loudest signal.
:: Oscillator voltage will change as you tune across the dial. This is normal and won't have an effect on operatrion as long as the osc keeps operating.
:::Hi, Im working on my Sparton 1568
:::http://www.nostalgiaair.org/PagesByModel/687/M0018687.pdf
:::IT works grea, except the lower frequency am won't work well.
:::During alignment @ 1500 There is -5 dc at the junction of c37, L12, and r17. When aligning lower end (600) it reads ~1.7 volts. I can get it to decrease but not increase. When the screwdriver is on the trimmer screw of the padder, The voltage goes up to over 2.5 volts. I noticed that this trimmer is Physically backwards to all of the others, could this do it?
:::WJR barely comes in, where as a station at 1200 is booming.
:::Im going to test some voltages and keep trying, I will be awake for some time yet.
:::Ian
:Hi Ian
: Don't use the padder to peak this voltage. Tune to the lowest station you receive and adjust padder for max volume while rocking tuning back and forth. The signal will come up.
: Wire wound or carbon resistors won't be a problem on the B+ line. You don't have to worry about inductance as there will be caps to ground on both sides of a resistor.
::When the padder C11 is screwed trightly the voltage goes up to about half of what the high end (1500) yields. I get NO staions below 1000 except WJR , but it is very faint. The eye tube doesnt move on lower stations , including the signal from the generator,
::The B+ was very high, I dropped it down with a large resistor, the bass decreased dramatically. Is this becasuse it is a wirewound resistor?
::Ian
:::Hi Ian
::: This radio has padder caps identified as C11, 12 and 13. These adjustments are used to peak up the low end of bands.
::: Adjust the padder while rocking tuning back and forth, listening to low end of the dial. Set for the loudest signal.
::: Oscillator voltage will change as you tune across the dial. This is normal and won't have an effect on operatrion as long as the osc keeps operating.
::::Hi, Im working on my Sparton 1568
::::http://www.nostalgiaair.org/PagesByModel/687/M0018687.pdf
::::IT works grea, except the lower frequency am won't work well.
::::During alignment @ 1500 There is -5 dc at the junction of c37, L12, and r17. When aligning lower end (600) it reads ~1.7 volts. I can get it to decrease but not increase. When the screwdriver is on the trimmer screw of the padder, The voltage goes up to over 2.5 volts. I noticed that this trimmer is Physically backwards to all of the others, could this do it?
::::WJR barely comes in, where as a station at 1200 is booming.
::::Im going to test some voltages and keep trying, I will be awake for some time yet.
::::Ian
:I think somthing is very wrong.
:Now the only station I can get is my own transmitter, and the generator. I think that the problem is the osccilator because every few minutes I have to retune the radio to my transmitter. IF output voltage is ~5 @ 1500, and .5 @ 600. When I put a screwdriver (one in paticular works better than the rest) the voltage goes up to 3.8. When I move my hand close to the RF or 6a8 tubes volume goes up. I have tried many tubes, and differnt types (metal, gt, g) no difference. Radio still recieves my transmitter faintly without the RF in the radio.
:I checked all resistors and replaced most.
:B+ came down a bit, so I removed the 1000 ohm wirewound, B+ is now ~425v (400 on paper)
:Help! Please!
::Hi Ian
:: Don't use the padder to peak this voltage. Tune to the lowest station you receive and adjust padder for max volume while rocking tuning back and forth. The signal will come up.
:: Wire wound or carbon resistors won't be a problem on the B+ line. You don't have to worry about inductance as there will be caps to ground on both sides of a resistor.
:::When the padder C11 is screwed trightly the voltage goes up to about half of what the high end (1500) yields. I get NO staions below 1000 except WJR , but it is very faint. The eye tube doesnt move on lower stations , including the signal from the generator,
:::The B+ was very high, I dropped it down with a large resistor, the bass decreased dramatically. Is this becasuse it is a wirewound resistor?
:::Ian
::::Hi Ian
:::: This radio has padder caps identified as C11, 12 and 13. These adjustments are used to peak up the low end of bands.
:::: Adjust the padder while rocking tuning back and forth, listening to low end of the dial. Set for the loudest signal.
:::: Oscillator voltage will change as you tune across the dial. This is normal and won't have an effect on operatrion as long as the osc keeps operating.
::::Norm
:::::Hi, Im working on my Sparton 1568
:::::http://www.nostalgiaair.org/PagesByModel/687/M0018687.pdf
:::::IT works grea, except the lower frequency am won't work well.
:::::During alignment @ 1500 There is -5 dc at the junction of c37, L12, and r17. When aligning lower end (600) it reads ~1.7 volts. I can get it to decrease but not increase. When the screwdriver is on the trimmer screw of the padder, The voltage goes up to over 2.5 volts. I noticed that this trimmer is Physically backwards to all of the others, could this do it?
:::::WJR barely comes in, where as a station at 1200 is booming.
:::::Im going to test some voltages and keep trying, I will be awake for some time yet.
:::::Ian
When a radio only receives a strong station the oscillator may not be operating? In that case a tuner will act somewhat as a volume control. Instead of changing stations it will have an effect on volume.
Bring your hand near the 6A8 and increase volume indicates antenna coil is open of stage not peaked up. Your hand is acting as an antenna. Do you have an antenna connected to the radio?
:Bump
:Any ideas anyone?
::I think somthing is very wrong.
::Now the only station I can get is my own transmitter, and the generator. I think that the problem is the osccilator because every few minutes I have to retune the radio to my transmitter. IF output voltage is ~5 @ 1500, and .5 @ 600. When I put a screwdriver (one in paticular works better than the rest) the voltage goes up to 3.8. When I move my hand close to the RF or 6a8 tubes volume goes up. I have tried many tubes, and differnt types (metal, gt, g) no difference. Radio still recieves my transmitter faintly without the RF in the radio.
::I checked all resistors and replaced most.
::B+ came down a bit, so I removed the 1000 ohm wirewound, B+ is now ~425v (400 on paper)
::Help! Please!
:::Hi Ian
::: Don't use the padder to peak this voltage. Tune to the lowest station you receive and adjust padder for max volume while rocking tuning back and forth. The signal will come up.
::: Wire wound or carbon resistors won't be a problem on the B+ line. You don't have to worry about inductance as there will be caps to ground on both sides of a resistor.
::::When the padder C11 is screwed trightly the voltage goes up to about half of what the high end (1500) yields. I get NO staions below 1000 except WJR , but it is very faint. The eye tube doesnt move on lower stations , including the signal from the generator,
::::The B+ was very high, I dropped it down with a large resistor, the bass decreased dramatically. Is this becasuse it is a wirewound resistor?
::::Ian
:::::Hi Ian
::::: This radio has padder caps identified as C11, 12 and 13. These adjustments are used to peak up the low end of bands.
::::: Adjust the padder while rocking tuning back and forth, listening to low end of the dial. Set for the loudest signal.
::::: Oscillator voltage will change as you tune across the dial. This is normal and won't have an effect on operatrion as long as the osc keeps operating.
:::::Norm
::::::Hi, Im working on my Sparton 1568
::::::http://www.nostalgiaair.org/PagesByModel/687/M0018687.pdf
::::::IT works grea, except the lower frequency am won't work well.
::::::During alignment @ 1500 There is -5 dc at the junction of c37, L12, and r17. When aligning lower end (600) it reads ~1.7 volts. I can get it to decrease but not increase. When the screwdriver is on the trimmer screw of the padder, The voltage goes up to over 2.5 volts. I noticed that this trimmer is Physically backwards to all of the others, could this do it?
::::::WJR barely comes in, where as a station at 1200 is booming.
::::::Im going to test some voltages and keep trying, I will be awake for some time yet.
::::::Ian
:Ian
: When a radio only receives a strong station the oscillator may not be operating? In that case a tuner will act somewhat as a volume control. Instead of changing stations it will have an effect on volume.
: Bring your hand near the 6A8 and increase volume indicates antenna coil is open of stage not peaked up. Your hand is acting as an antenna. Do you have an antenna connected to the radio?
::Bump
::Any ideas anyone?
:::I think somthing is very wrong.
:::Now the only station I can get is my own transmitter, and the generator. I think that the problem is the osccilator because every few minutes I have to retune the radio to my transmitter. IF output voltage is ~5 @ 1500, and .5 @ 600. When I put a screwdriver (one in paticular works better than the rest) the voltage goes up to 3.8. When I move my hand close to the RF or 6a8 tubes volume goes up. I have tried many tubes, and differnt types (metal, gt, g) no difference. Radio still recieves my transmitter faintly without the RF in the radio.
:::I checked all resistors and replaced most.
:::B+ came down a bit, so I removed the 1000 ohm wirewound, B+ is now ~425v (400 on paper)
:::Help! Please!
::::Hi Ian
:::: Don't use the padder to peak this voltage. Tune to the lowest station you receive and adjust padder for max volume while rocking tuning back and forth. The signal will come up.
:::: Wire wound or carbon resistors won't be a problem on the B+ line. You don't have to worry about inductance as there will be caps to ground on both sides of a resistor.
::::Norm
:::::When the padder C11 is screwed trightly the voltage goes up to about half of what the high end (1500) yields. I get NO staions below 1000 except WJR , but it is very faint. The eye tube doesnt move on lower stations , including the signal from the generator,
:::::The B+ was very high, I dropped it down with a large resistor, the bass decreased dramatically. Is this becasuse it is a wirewound resistor?
:::::Ian
::::::Hi Ian
:::::: This radio has padder caps identified as C11, 12 and 13. These adjustments are used to peak up the low end of bands.
:::::: Adjust the padder while rocking tuning back and forth, listening to low end of the dial. Set for the loudest signal.
:::::: Oscillator voltage will change as you tune across the dial. This is normal and won't have an effect on operatrion as long as the osc keeps operating.
::::::Norm
:::::::Hi, Im working on my Sparton 1568
:::::::http://www.nostalgiaair.org/PagesByModel/687/M0018687.pdf
:::::::IT works grea, except the lower frequency am won't work well.
:::::::During alignment @ 1500 There is -5 dc at the junction of c37, L12, and r17. When aligning lower end (600) it reads ~1.7 volts. I can get it to decrease but not increase. When the screwdriver is on the trimmer screw of the padder, The voltage goes up to over 2.5 volts. I noticed that this trimmer is Physically backwards to all of the others, could this do it?
:::::::WJR barely comes in, where as a station at 1200 is booming.
:::::::Im going to test some voltages and keep trying, I will be awake for some time yet.
:::::::Ian
:I have an antenna attached to the radio when not aligning it because the siggenerator goes to antenna post. I Will check for an open coil.
::Ian
:: When a radio only receives a strong station the oscillator may not be operating? In that case a tuner will act somewhat as a volume control. Instead of changing stations it will have an effect on volume.
:: Bring your hand near the 6A8 and increase volume indicates antenna coil is open of stage not peaked up. Your hand is acting as an antenna. Do you have an antenna connected to the radio?
:::Bump
:::Any ideas anyone?
::::I think somthing is very wrong.
::::Now the only station I can get is my own transmitter, and the generator. I think that the problem is the osccilator because every few minutes I have to retune the radio to my transmitter. IF output voltage is ~5 @ 1500, and .5 @ 600. When I put a screwdriver (one in paticular works better than the rest) the voltage goes up to 3.8. When I move my hand close to the RF or 6a8 tubes volume goes up. I have tried many tubes, and differnt types (metal, gt, g) no difference. Radio still recieves my transmitter faintly without the RF in the radio.
::::I checked all resistors and replaced most.
::::B+ came down a bit, so I removed the 1000 ohm wirewound, B+ is now ~425v (400 on paper)
::::Help! Please!
:::::Hi Ian
::::: Don't use the padder to peak this voltage. Tune to the lowest station you receive and adjust padder for max volume while rocking tuning back and forth. The signal will come up.
::::: Wire wound or carbon resistors won't be a problem on the B+ line. You don't have to worry about inductance as there will be caps to ground on both sides of a resistor.
:::::Norm
::::::When the padder C11 is screwed trightly the voltage goes up to about half of what the high end (1500) yields. I get NO staions below 1000 except WJR , but it is very faint. The eye tube doesnt move on lower stations , including the signal from the generator,
::::::The B+ was very high, I dropped it down with a large resistor, the bass decreased dramatically. Is this becasuse it is a wirewound resistor?
::::::Ian
:::::::Hi Ian
::::::: This radio has padder caps identified as C11, 12 and 13. These adjustments are used to peak up the low end of bands.
::::::: Adjust the padder while rocking tuning back and forth, listening to low end of the dial. Set for the loudest signal.
::::::: Oscillator voltage will change as you tune across the dial. This is normal and won't have an effect on operatrion as long as the osc keeps operating.
:::::::Norm
::::::::Hi, Im working on my Sparton 1568
::::::::http://www.nostalgiaair.org/PagesByModel/687/M0018687.pdf
::::::::IT works grea, except the lower frequency am won't work well.
::::::::During alignment @ 1500 There is -5 dc at the junction of c37, L12, and r17. When aligning lower end (600) it reads ~1.7 volts. I can get it to decrease but not increase. When the screwdriver is on the trimmer screw of the padder, The voltage goes up to over 2.5 volts. I noticed that this trimmer is Physically backwards to all of the others, could this do it?
::::::::WJR barely comes in, where as a station at 1200 is booming.
::::::::Im going to test some voltages and keep trying, I will be awake for some time yet.
::::::::Ian
Glad you found it.. 1460 is near top end of the dial. Use trimmers to peak up this end. Trimmers have the most effect at high end of a dial.
:I feel really dumb right now.
:The jumper between the G and D position fell out
:Put it back, and it gets MANY stations, wjr came in at over 6 volts.
:Now, the audio isnt the best scratchy and treble is a little low.. will work on it, and I still cant get one local station WPON 1460
::I have an antenna attached to the radio when not aligning it because the siggenerator goes to antenna post. I Will check for an open coil.
:::Ian
::: When a radio only receives a strong station the oscillator may not be operating? In that case a tuner will act somewhat as a volume control. Instead of changing stations it will have an effect on volume.
::: Bring your hand near the 6A8 and increase volume indicates antenna coil is open of stage not peaked up. Your hand is acting as an antenna. Do you have an antenna connected to the radio?
::::Bump
::::Any ideas anyone?
:::::I think somthing is very wrong.
:::::Now the only station I can get is my own transmitter, and the generator. I think that the problem is the osccilator because every few minutes I have to retune the radio to my transmitter. IF output voltage is ~5 @ 1500, and .5 @ 600. When I put a screwdriver (one in paticular works better than the rest) the voltage goes up to 3.8. When I move my hand close to the RF or 6a8 tubes volume goes up. I have tried many tubes, and differnt types (metal, gt, g) no difference. Radio still recieves my transmitter faintly without the RF in the radio.
:::::I checked all resistors and replaced most.
:::::B+ came down a bit, so I removed the 1000 ohm wirewound, B+ is now ~425v (400 on paper)
:::::Help! Please!
::::::Hi Ian
:::::: Don't use the padder to peak this voltage. Tune to the lowest station you receive and adjust padder for max volume while rocking tuning back and forth. The signal will come up.
:::::: Wire wound or carbon resistors won't be a problem on the B+ line. You don't have to worry about inductance as there will be caps to ground on both sides of a resistor.
::::::Norm
:::::::When the padder C11 is screwed trightly the voltage goes up to about half of what the high end (1500) yields. I get NO staions below 1000 except WJR , but it is very faint. The eye tube doesnt move on lower stations , including the signal from the generator,
:::::::The B+ was very high, I dropped it down with a large resistor, the bass decreased dramatically. Is this becasuse it is a wirewound resistor?
:::::::Ian
::::::::Hi Ian
:::::::: This radio has padder caps identified as C11, 12 and 13. These adjustments are used to peak up the low end of bands.
:::::::: Adjust the padder while rocking tuning back and forth, listening to low end of the dial. Set for the loudest signal.
:::::::: Oscillator voltage will change as you tune across the dial. This is normal and won't have an effect on operatrion as long as the osc keeps operating.
::::::::Norm
:::::::::Hi, Im working on my Sparton 1568
:::::::::http://www.nostalgiaair.org/PagesByModel/687/M0018687.pdf
:::::::::IT works grea, except the lower frequency am won't work well.
:::::::::During alignment @ 1500 There is -5 dc at the junction of c37, L12, and r17. When aligning lower end (600) it reads ~1.7 volts. I can get it to decrease but not increase. When the screwdriver is on the trimmer screw of the padder, The voltage goes up to over 2.5 volts. I noticed that this trimmer is Physically backwards to all of the others, could this do it?
:::::::::WJR barely comes in, where as a station at 1200 is booming.
:::::::::Im going to test some voltages and keep trying, I will be awake for some time yet.
:::::::::Ian
This sets AVC design: |
Ye Olde Spartacus 1568 Chassis Mark-Up Schematique: |
::It works ok. Eye tube closes completely on my transmitter, and partially on wjr. Gets many stations with no movement. Sound quality is excellent. Voltages normal except one. Pin 6 of the 6c5 is supposed to have 20v it has 1-5v on it. ALL resistors have been checked or replaced. When the off/afc/afc+expander switch is switched from off to afc, there is a loud pop, and a decrease in volume, but no change in signal strength. When switched to expander, signal voltage drops, volume drops, and eye tube opens more (can retune to get back to same %closed but with less volume) AFC doesn’t help at all, makes quieter. I have no experience with the AFC/expander/discriminator circuit. Please help someone
::Thanks Norm for the previous help.
::Ian
