West Tech Services is listed in the AES catalog as having needles & cartridges. Charles Carey can be reached at 888-828-8455. The old Astatic cartridge may also be bad?
Clean up the motor and use a light oil. Be sure to keep it off rubber parts.
: Hi- I hase just bought a record player that is used with a radio, I need a needle for it, also some service info. It has a "astatic" cartridge # 62-1 and says use a # N27-1 needle. Where can I get a needle, and what can I use to lubricate the motor and running gear, as it is gummed up. It turns slow but all seems to work.Thanks any one, dennis..
: Hi Dennis
: West Tech Services is listed in the AES catalog as having needles & cartridges. Charles Carey can be reached at 888-828-8455. The old Astatic cartridge may also be bad?
: Clean up the motor and use a light oil. Be sure to keep it off rubber parts.
: Norm
: : Hi- I hase just bought a record player that is used with a radio, I need a needle for it, also some service info. It has a "astatic" cartridge # 62-1 and says use a # N27-1 needle. Where can I get a needle, and what can I use to lubricate the motor and running gear, as it is gummed up. It turns slow but all seems to work.Thanks any one, dennis..
