Stark 9-66 tube tester
2/15/2010 11:00:27 AMborko
I am looking for calibration procedure for Stark 9-66 tube tester.
2/15/2010 4:04:10 PMBob Masse
:I am looking for calibration procedure for Stark 9-66 tube tester.
:Hi! borko,
Google (Pacific TV Online schematics) and click on same link and scroll down to find Stark 9-66 info.You can also take a look at the Hickok 533A to see if that works. The Stark 9-66 and the Hickok 533a have the same basic schematic but have different panel meters.Also the schematic for both calls for the R-10 resistor to be 500K but the parts list calls for R-10 to be 330K.So you probably have to go with what is in your tester.
: Bob Masse
2/16/2010 6:44:30 AMborko
::I am looking for calibration procedure for Stark 9-66 tube tester.
::Hi! borko,
:Google (Pacific TV Online schematics) and click on same link and scroll down to find Stark 9-66 info.You can also take a look at the Hickok 533A to see if that works. The Stark 9-66 and the Hickok 533a have the same basic schematic but have different panel meters.Also the schematic for both calls for the R-10 resistor to be 500K but the parts list calls for R-10 to be 330K.So you probably have to go with what is in your tester.
:: Bob Masse
:: Thanks!
