Loctals are a whole other matter. bend only towards the dimple as was suggested. WD40 sprayed on the locking (center pin) of the tube usually helps. This locking pin, and it's retainer can indeed lock up. You can gently pry it apart after the WD40 sinks in with a dental explorer or tiny screwdriver to bust the corrosion glue that has formed.
Of course everything has to be cleaned up before you re-insert the tube.
One other thing, label each tube with a china marker beause when you attempt to clean them, the decals will come off. Want to preservethe decals? Clean very gently with paint thinner. Hope this helps.
:::You can damage the tube--seal, wires, etc. Always pull from the base, unless the tube comes out easily, and the bulb is secured well to the base.
:::T.
::I usually put a slot screwdriver under the base while I'm rocking the tube gently. It seems that dirt, moisture and age can lock those pins to the contacts. The loctals should be moved towards the bump on the side of the metal base. Octals should not be moved too far in any direction or you can break the key (use JB Weld if you do).
::Johnnysan-
:I had a radio that had a bad socket and the last person to work on it soldered the tube to the socket.
:Hardest tube I ever removed LOL
