Majestic Model 15 -Osc. coil and 1st IF Assembly needed
1/11/1999 11:41:44 AMTom Perry
Hi, I am in the process of restoring an old Majestic model 15 Receiver and am trying to find a replacement osc. coil and 1st IF assembly for this unit. The Primary of the IF coil is open - even if you have a specs, it would be helpful, if I have to re-wind it. The unit that is defective was made by Hammerlund andf it's a 175khz IF any info would be appreciated. ..... Thank you Tom
1/11/1999 1:25:38 PMNorm Leal
: Hi, I am in the process of restoring an old Majestic model 15 Receiver and am trying to find a replacement osc. coil and 1st IF assembly for this unit. The Primary of the IF coil is open - even if you have a specs, it would be helpful, if I have to re-wind it. The unit that is defective was made by Hammerlund andf it's a 175khz IF any info would be appreciated. ..... Thank you Tom
Hi Tom
If you don't come up with an IF transformer it can be bypassed. Put a 22K resistor across the open winding to supply plate voltage to the 35/51 tube. Add a small cap 100-200pf from the plate to the next tube grid.
Hopefully your osc. coil doesn't have a problem. With the IF Transformer open the oscillator will not run since the plate voltage will be missing on the tube.
Good luck..
1/13/1999 6:35:21 PMBob Rosengarten
: : Hi, I am in the process of restoring an old Majestic model 15 Receiver and am trying to find a replacement osc. coil and 1st IF assembly for this unit. The Primary of the IF coil is open - even if you have a specs, it would be helpful, if I have to re-wind it. The unit that is defective was made by Hammerlund andf it's a 175khz IF any info would be appreciated. ..... Thank you Tom
: Hi Tom
: If you don't come up with an IF transformer it can be bypassed. Put a 22K resistor across the open winding to supply plate voltage to the 35/51 tube. Add a small cap 100-200pf from the plate to the next tube grid.
: Hopefully your osc. coil doesn't have a problem. With the IF Transformer open the oscillator will not run since the plate voltage will be missing on the tube.
: Good luck..
: Norm
Tom,
Are you sure the coil is really open? I had an Apex 7 that seemed to have open IFs (one is in common with oscillator coil too!) until I opened the cans and checked the lugs-the screws were tarnished and were not making contact.
Bob Rosengarten
9/25/1999 12:15:26 AMdel fankhauser
been there done that. it will probably need the second if as well. i found the first and then the second was green as the giant.
try playthings of the past. 216-251-3714. also look up warren parks web page. i think he is listed above concerning other questions.
you are looking for a meissner direct replacement. do not remember the number. but majestics coils were all bad. i have some but need them
for other majestics in the future.
a majestic collector in florida email. chip.taylor@cwix.com
