Sir Scott. . . . .
From my memories of having had one back on day one, unpackaged from its box, the wire was long enough to have made a hank of ~6 inch coils that were conpressed together to be retained with a rubber band? . . being pre twist-em days. The wire was
dark brown DOUBLE COTTON covered and quite flexible. Going by memory, seems like the total length would have been
~12-15 ft but probably NOT as long as 25 feet. Keeping up with manufacturers practice of no more than was deemed necessary.
At any rate, it was in excess of your mentioned skimpy length.
Vaguely remembering the antenna coil proper as then being mounted up at or near the left corner of the top of the speaker. Thereby the antenna coil is RF shielded from signal reception being in a metal cabinet, excluding the open end at the rear of the radio.Therefore, RF needed to be "remoted in " via the incoming aerial wire.
Since this set IS merely a "4 banger", less the use of an additional dedicated IF amplifier, it tends to be categorized as a metropolitan receiver.
If the set still happens to be in pristine condition in its alignment adjustments , you might make a stab at the required length of that
extended antenna / aerial wire hanks length of wire in the following manner:
It would be dependent upon the radio being placed on a wooden/plastic table, STILL having a 25 ft + ? pocket tape measure that has its casing being of all metal construction, not in an overall plastic clamshell housing.(Nor . . fooled ya ! . . . silver mylarized plastic housing)
That then lets you connect the antenna wire "stub" via the compression against the metal casing of the bare wire end and a
multi encircling of a rubber band. The whole tape case is then temp . . . " C " clamped . . .weighted . . ? . . etc . .to the
. . .not metal . .table top which you are working upon.
Then you pick out a very weak station at the high end of the band and take the tape measures end tab, using a folded over
6 inch length of cardboard. (This precludes any finger coupled capacitive coupling of your bodys affect into the evaluation.)
Then you crank up the volume on that feeble station and start walking out the length of the tape end and listening for an optimization of reception.
That then gives a guideline of MINIMAL wire length required.
