http://www.nostalgiaair.org/PagesByModel/325/M0015325.pdf
If you want to figure out the voltages on your own, consult your tube manual for the plate and screen grid impedances for the the tubes you mentioned. The RF screen grids are in parallel with eachother and the oscillator plate, and R17. They are all in series with R14. This will tell you approximately what the voltage drop should be from the main B+ circuit to the other side of R14. The RF plates are all tied into the main B+ line through their respective coils, which have rather low resistances. To be more exact, you must consider all of the loads within the radio (or the resistance of the entire radio, including the rectifier), and this gets complicated, but it is possible to calculate approximately. Things are further complicated by the presence of signals, as they increase the impedance of coils, though if you wish to calculate all of the voltages on your own, you should get a good approximation without this extra information.
I am guessing that you just want the information on page 5, but if you really want to calculate all of this out yourself, it is possible.
:...Sorry. You said Canadian 97K-1, which is not the schematic I looked at here (U.S. 97K). Hopefully the circuitry is similar. If not, though, the information I gave will help you calculate approximately what the voltages should be throughout the set. Draw a schematic of pure resistances, representing all tubes, resistors, and coils in the set, and break it down from the mass unit to all of the separate units. For resistors in series, you just add them. For resistances in parallel, it's 1/(1/R1+1/R2...).
:T.
RCA 97K . . . series . . . SCHEMATIC: ![]() |
Would C38 (if leaky) be a possibility? It is well buried in the chassis and I have not replaced yet.
Brian
:Sir Brian. . . . . .
:On that set of your's, there is basically just the full B+ buss and the sub B+ buss.
:If you will consult the attached marked up schema, one sees the RED MARKUP B+ moving to the right from its derivation at the rctifier toobie. Then upwards, to feed that full supply level to the AF output tube supply.
:Further tracking of that buss, transversuing to the left, has a minor tap off to further drop the B+ to the early stage AF tube. Next stop to the left is a full supply B+ level to the target anode of the eye tube.
:To the left from that last area is the feed to the plate of your 6K7 if amp tube along with a further path to the left to the plate of the hexode portion of the 6K8.
:Now, in going back to the sub B+ buss, it is derived from a voltage divider bridge of R14-R17 [YELLOW]that ties into the main B+ buss.
:The sub B+ power flow is to the left via the FUSCIA MARKUP it branches apart to feed the screen grids of the 6K7 and the 6K8 on one run.
:The other run feeds over to the left and then up to the plate of the oscillator section of the 6K8.
:The sub B+ level would be dependent upon the main B+ level, the ratio of the R14-17 divider resistors or the current consumption of the tubes tied in to it.
:Seems like a slight fault with the sub B+ level as it now stands, are R14 and R17 to spec ?
:On the other aspect, of the 300VDC level on the main B+ buss , a wee bit high, but I do consult with the RCA Radiotron Tube and Design manual and see the 6K8 being used up to the mid to high 200V levels.
:Matter of fact, in its compared performance with 100 VDC on the plate of the hexode , the conversion efficiency amd overall performance is appreciably better when using the higher voltage.
:An aside thought, since I am uncertain about WHICH post, recently, and WHO it is / was . . . in which case was the mentioning of the use of a 1 K value power resistor in place of a field coil on a radio.
:Should this happen to be the set involved, the reason for the higher derived B+ voltage just might be due to the
:use of a 1K value of power series dropping / filter resistor. The value should be 1,500 ohms instead.
