magnavox model 1sc261f
2/2/2010 9:57:05 AMDaniel Smith
hello i need help for this model 1sc261f it says run 1 and amp board has 8002-00 on it .. for this record player it has three tubes two 50eh5 and one 7025 it has a burnt out resistor that connects to a diode then on to the tubes... i think it drops the voltage but im not sue and im looking for the value of that resistor ..the rsistor is about the size of a stick of gum maybe longer ? and had wire in it..it was completly crumbled apart.. i heard they were called glo bar rsistors ? but im not sure any help would be great thanks dan
2/2/2010 10:28:00 AMCarl T
Daniel,
I believe the resistor should be 22-ohm, 2-watt.
Carl T
: hello i need help for this model 1sc261f it says run 1 and amp board has 8002-00 on it .. for this record player it has three tubes two 50eh5 and one 7025 it has a burnt out resistor that connects to a diode then on to the tubes... i think it drops the voltage but im not sue and im looking for the value of that resistor ..the rsistor is about the size of a stick of gum maybe longer ? and had wire in it..it was completly crumbled apart.. i heard they were called glo bar rsistors ? but im not sure any help would be great thanks dan
