Resistor Value for Simpson 260
1/10/1999 3:35:30 PMA.B.Tiller
I need the value of the resistor R-18 on the circuit
card in my Simpson Meter. Any Help would be appreciated
as I don't have a schematic. Thanks A.B. Tiller
1/11/1999 7:34:10 AMDon Black
: I need the value of the resistor R-18 on the circuit
: card in my Simpson Meter. Any Help would be appreciated
: as I don't have a schematic. Thanks A.B. Tiller
Hi A. B. Tiller,
The value of R18 in your Simpson 260 meter is 22.5 ohms. It's connected between the 100 mA and 10 Amps switch terminals (R19 and R5). When I get my scanner set up I'll send you a schematic and data for the meter. Perhaps you can select a high tolerance 22 ohm resistor with a digital meter at 22.5 ohms. I suggest a 1 or 2 watt metal film or wire wound resistor. Otherwise you can wind a resistor to the right value from resistance wire. Good luck, if you need any more info just email me. Don.
3/30/1999 8:06:44 PMDrew Harris
: : I need the value of the resistor R-18 on the circuit
: : card in my Simpson Meter. Any Help would be appreciated
: : as I don't have a schematic. Thanks A.B. Tiller
: Hi A. B. Tiller,
: I work for Simpson Electric and for the Simpson models 260-7 and 260-8, the value of R18 in these meters is 138.0 ohms (1/2 watt, 1.0% accuracy). If you have an older series of 260, please let me know and I can provide that information to you as well. The R14 resistor is the one that has a value of 22.5 ohms - please do not try putting a 22.5 ohm resistor in place of the R18 138.0 ohm resistor. If you have any other questions please email me at HarrisDrew@aol.com. The "series" number for your 260 can be found on the bottom center of the dial below the model number (260). Thanks,
Drew Harris
West Coast RSM
Simpson Electric Co.
1/9/2000 3:16:49 PMTom Callaghan
: : : I need the value of the resistor R-18 on the circuit
: : : card in my Simpson Meter. Any Help would be appreciated
: : : as I don't have a schematic. Thanks A.B. Tiller
: : Hi A. B. Tiller,
: : I work for Simpson Electric and for the Simpson models 260-7 and 260-8, the value of R18 in these meters is 138.0 ohms (1/2 watt, 1.0% accuracy). If you have an older series of 260, please let me know and I can provide that information to you as well. The R14 resistor is the one that has a value of 22.5 ohms - please do not try putting a 22.5 ohm resistor in place of the R18 138.0 ohm resistor. If you have any other questions please email me at HarrisDrew@aol.com. The "series" number for your 260 can be found on the bottom center of the dial below the model number (260). Thanks,
: Drew Harris
: West Coast RSM
: Simpson Electric Co.
I have a Simpson Model 260 Ser No. 18842 and need an
operation manual. Probably an overhaul or at least an
IRAN(Inspect and Repair and Necessary) is also in
order due to damage from drop. Are there replacement
cases available? Thansk
11/28/2000 9:54:13 PMDJ Webre
: Drew Harris
: West Coast RSM
11/28/2000 9:57:07 PMDJ Webre
Could you advise me the manufacture and part number of the battery connectors? Are this available from Simpson?
: Drew Harris
: West Coast RSM
