It was constructed as a normal crystal set, with a stolen earphone and a coil to be connected to arial and earth. As detector they had used a razor blade mounted on a piece of wood and a safety pin mounted standing on the same piece of wood so that the sharp end of the safety pin could be moved around touching the razor blade. It was said to work well nighttime receiving latest war news from allied stations in free India. Was that what you meant?
73 / Karl
: Hello,
: In one of the war museums along the River Kwai in Thailand I saw a replica of the several hidden receivers made by the european POWs (at risk of death penalty).
: It was constructed as a normal crystal set, with a stolen earphone and a coil to be connected to arial and earth. As detector they had used a razor blade mounted on a piece of wood and a safety pin mounted standing on the same piece of wood so that the sharp end of the safety pin could be moved around touching the razor blade. It was said to work well nighttime receiving latest war news from allied stations in free India. Was that what you meant?
: 73 / Karl
: : Hello,
: : In one of the war museums along the River Kwai in Thailand I saw a replica of the several hidden receivers made by the european POWs (at risk of death penalty).
: : It was constructed as a normal crystal set, with a stolen earphone and a coil to be connected to arial and earth. As detector they had used a razor blade mounted on a piece of wood and a safety pin mounted standing on the same piece of wood so that the sharp end of the safety pin could be moved around touching the razor blade. It was said to work well nighttime receiving latest war news from allied stations in free India. Was that what you meant?
: : 73 / Karl
The razor blade does need to be rusty. A clean one wouldn't lend itself too well to the creation of a diode.
I once made one of these where, instead of a pin, I used a small piece of pencil lead with a copper wire wrapped around it as the probe to touch the razor blade.
John Dunn
ambertec@ieee.org
#1) Tim Beaudoin 5362 Greenplain Road Norfolk, VA 23502
#2) Ambrose Costanzo 2777 Briargrove Dr. #839 Houston, TX 77057
#3) J.Dougherty 9 Blue Mountain Court Kunkletown, PA 18058
#4) M Frank 418 Parkview Way Newtown PA 18940
#5) B Shepherd PO Box 831 Lockeford, CA 95237
#6) J. Stava 8037 N. 32nd Dr. #3 Phoenix, AZ 85051
STEP 2: Now take the #1 name off the list that you see above, move the other names up (6 becomes 5, 5 becomes 4, etc...) and add YOUR name as #6 on the list. STEP 3: Change anything you need to, but try to keep this article as close to original as possible. Now, post your amended article to at least 200 newsgroups. (I think there are close to 24,000 groups) All you need is 200, but remember, the more you post, the more money you make! You won't get very much unless you post like crazy. :) This is perfectly legal! If you have any doubts, refer to Title 18 Sec. 1302 & 1341 of the Postal lottery laws. Keep a copy of these steps for yourself and, whenever you need money, you can use it again, and again. PLEASE REMEMBER that this program remains successful because of the honesty and integrity of the participants and by their carefully adhering to the directions. Look at it this way: if you are of integrity and honesty, the program will continue and the money that so many others have received will come your way. NOTE: You may want to retain every name and address sent to you, either on a computer or hard copy and keep the notes people send you. This VERIFIES that you are truly providing a service. (Also, it might be a good idea to wrap the $1 bill in dark paper to reduce the risk of mail theft.) So, as each post is downloaded and the directions carefully followed, six members will be reimbursed for their participation as a List Developer with one dollar each. Your name will move up the list geometrically so that when your name reaches the #1 position you will be receiving thousands of dollars in CASH!!! What an opportunity for only $6.00 - $1.00 for each of the first six people listed above. Send it now, add your own name to the list and you're in business!
---DIRECTIONS ----- FOR HOW TO POST TO NEWSGROUPS------------
Step 1) You do not need to re-type this entire letter to do your own posting. Simply put your cursor at the beginning of this letter and drag your cursor to the bottom of this document, and select 'copy' from the edit menu. This will copy the entire letter into the computer's memory. Step 2) Open a blank 'notepad' file and place your cursor at the top of the blank page. From the 'edit' menu select 'paste'. This will paste a copy of the letter into notepad so that you can add your name to the list. Step 3) Save your new notepad file as a .txt file. If you want to do your postings in different settings, you'll always have this file to go back to. Step 4) Use Netscape or Internet Explorer and try searching for various newsgroups (on-line forums, message boards, chat sites, discussions.) Step 5) Visit these message boards and post this article as a new message by highlighting the text of this letter and selecting paste from the edit menu. Fill in the Subject, this will be the header that everyone sees as they scroll through the list of postings in a particular group, click the post message button. You're done with your first one! Congratulations!!! THAT'S IT! All you have to do is jump to different newsgroups and post away, after you get the hang of it, it will take about 30 seconds for each newsgroup!
**REMEMBER, THE MORE NEWSGROUPS YOU POST IN, THE MORE MONEY YOU WILL MAKE! BUT YOU HAVE TO POST A MINIMUM OF 200**
That's it! You will begin receiving money from around the world within days! You may eventually want to rent a P.O. Box due to the large amount of mail you will receive. If you wish to stay anonymous, you can invent a name to use, as long as the postman will deliver it. **JUST MAKE SURE ALL THE ADDRESSES ARE CORRECT.** Now, each of the 5 persons who just sent me $1.00 make the MINIMUM 200 postings, each with my name at #5 and only 5 persons respond to each of the original 5, that is another $25.00 for me, now those 25 each make 200 MINIMUM posts with my name at #4 and only 5 replies each, I will bring in an additional $125.00! Now, those 125 persons turn around and post the MINIMUM 200 with my name at #3 and only receive 5 replies each, I will make an additional $625.00! OK, now here is the fun part, each of those 625 persons post a MINIMUM 200 letters with my name at #2 and they each only receive 5 replies, that just made me $3,125.00!!! Those 3,125 persons will all deliver this message to 200 newsgroups with my name at #1 and if still 5 persons per 200 newsgroups react I will receive $15,625.00! With an original investment of only $6.00! AMAZING! When your name is no longer on the list, you just take the latest posting in the newsgroups, and send out another $6.00 to names on the list, putting your name at number 6 again. And start posting again. The thing to remember is: do you realize that thousands of people all over the world are joining the Internet and reading these articles everyday?, JUST LIKE YOU are now!! So, can you afford $6.00 and see if it really works?? I think so... People have said, "what if the plan is played out and no one sends you the money? So what! What are the chances of that happening when there are tons of new honest users and new honest people who are joining the Internet and newsgroups everyday and are willing to give it a try? Estimates are at 20,000 to 50,000 new users, every day, with thousands of those joining the actual Internet. Remember, play FAIRLY and HONESTLY and this will really work.
WHAT GOES AROUND, COMES AROUND!!! GOD BLESS!
