1/19/2010 1:56:22 PMWarren(83420:0)
Table top radio (wood) Says "General" Tube line up
25Z5 43 6C6 6D6 Round dial 2-1/4 inch round in front of the 5 inch speaker. Has two #45 lamps. plate on chassis says " Factory F " Chicago. Any idea what the model would be ?
1/19/2010 4:08:16 PMBob H(83422:83420)
:Table top radio (wood) Says "General" Tube line up
:25Z5 43 6C6 6D6 Round dial 2-1/4 inch round in front of the 5 inch speaker. Has two #45 lamps. plate on chassis says " Factory F " Chicago. Any idea what the model would be ?
1/19/2010 5:16:48 PMWarren(83423:83422)
This one may have had the two 12Z3 tubes at one time. The chassis has a hole where a socket was. The line cord has been replaced, and dropping resistors have been added. The original speaker has been replaced with a PM type. It has a frame type filter choke added under the chassis. My only concern is the B+ seems to high. The choke only has 270 ohms resistance. No other diveder resistors. When I disconnect the heater string, and the B+ starts to fall, the set plays louder, and performance seems better before it dies.
