dial replacement information for 1932 Zenette
1/18/2010 7:47:17 PMdan livesay
hello
I need help replaceing the dial cord on a 1932 seven tube zenette cathedral.The cord was gone when I got the set.
1/18/2010 11:56:42 PMNadz.W
What model? if it is a drum dial like a model MH or BH I can post a homebrew diagram for you.
NADS
hello
: I need help replaceing the dial cord on a 1932 seven tube zenette cathedral.The cord was gone when I got the set.
1/19/2010 12:06:22 AMdan livesay
:What model? if it is a drum dial like a model MH or BH I can post a homebrew diagram for you.
:NADS hello--thanks for your reply--the zenette is chassis model 2022. the model number is L H 210
:hello
:: I need help replaceing the dial cord on a 1932 seven tube zenette cathedral.The cord was gone when I got the set.
1/19/2010 12:25:39 AMNadz.w
Hello
This is a diagram I made for a Zenette model BH I Repaired.
The stringing should be very similar for the LH If i remember,Maybe slightly different were the Spring clips to drum if any.
Hope I post this image right
Hope this is of some help.
NADS
1/19/2010 11:30:16 PMdan livesay
:Hello
:This is a diagram I made for a Zenette model BH I Repaired.
:The stringing should be very similar for the LH If i remember,Maybe slightly different were the Spring clips to drum if any.
:Hope I post this image right
:Hope this is of some help.
:NADS
:hello; Thank you very much. Your drawing was a life saver.
1/20/2010 8:35:28 PMNadz.W
Hello,
You're welcome.
I Was more than glad I could help.
NADS
::hello; Thank you very much. Your drawing was a life saver.
