If it is going to power more than that, you may want a switch in series (with the fuse) to be able to switch off in case of extended down time or low battery.
:From the key power switch, (hot side) add a inline fuse and wire to your radios. No need for any 9 volt back up then.
Hi Steve, you are correct we can't hard wire to any of the trucks , I guess they have had too many computer failures due to bad wiring hooh ups.
Elton
You will need a pretty huge value capacitor to replace the 9V battery.You can find memory ackup capacitors on the market for a few dollars (1F) but they are only 5V. There might be some available at higher voltages.
Look at websites such as electronics goldmine and similar surplus websites. Search for at least 1F capacitors (that is 1 Farad, not microFarad!)
Something else to think about is to use a rechargable 9 Volt battery. BG Micro has one at a very good price, I have a charger and change the depleated battery with a fresh one as required.
:You will need a pretty huge value capacitor to replace the 9V battery.You can find memory ackup capacitors on the market for a few dollars (1F) but they are only 5V. There might be some available at higher voltages.
:Look at websites such as electronics goldmine and similar surplus websites. Search for at least 1F capacitors (that is 1 Farad, not microFarad!)
If you have room, a holder with 6 penlite (AA) cells wired in series will make up a 9 volt battery that will last at least five times longer than a single 9 volt. Larger cells will last even longer.
:::Hi all I drive truck and as all truckers do , I built a radio box to house the C.B. and stereo radio, this truck the power is switched by the key so to keep the memory on the radio, I use a 9 volt battery. It works OK but the down side is I have to replace the battery every few months. Is there a circuit that could use a capacitor to replace the battery in this case? and save me batteries?
:::Thanks
:::Elton
Plus . . . no extra charge . . . when being used in ye olde trucke . . .there is a very mild trickle charge being provided for the add on memory storage battery via the 330 ohm 1/2 watt .
Sir Elton. . . . . (John?)
Methinks that if you have that radio hook up as per diagram # 1, that you are getting some additional current
consumption on that battery that you are showing used as memory retention.
Look via the Fuscia path and one sees the YELLOW resistor indicating potential phantom leakage thru the radio proper.
If the hook up was changed, as per # 2, the backward leakage path would be blocked by the aditional use of an isolation / steering
diode as is shown by its FUSCIA path .
Could be as simple as a common switching diode 1N914 / 4148 or as commonly found as a power diode
1N4001---4007.
Your 9V alkaline should then almost be shelf life, with that systems CMOS’s , femto - - - micro ampere memory retention requirements drain.
: : ![]() : : : : : :Sir Elton. . . . . (John?) : : :Methinks that if you have that radio hook up as per diagram # 1, that you are getting some additional current :consumption on that battery that you are showing used as memory retention. : : :Look via the Fuscia path and one sees the YELLOW resistor indicating potential phantom leakage thru the radio proper. : : : : :If the hook up was changed, as per # 2, the backward leakage path would be blocked by the aditional use of an isolation / steering :diode as is shown by its FUSCIA path . : : :Could be as simple as a common switching diode 1N914 / 4148 or as commonly found as a power diode :1N4001---4007. : : : :Plus . . . no extra charge . . . when being used in ye olde trucke . . .there is a very mild trickle charge being provided for the add on memory storage battery via the 330 ohm 1/2 watt . : : :Your 9V alkaline should then almost be shelf life, with that systems CMOS’s , femto - - - micro ampere memory retention requirements drain. : : : : : ![]() : : : : : :73's de Edd : : : ![]() : |
