Philco 46-1213 FM Distortion
1/14/2010 4:10:50 PMBill Vaughan
My Philco 46-1213 recently developed distortion throughout the FM band, worse at the higher end of the dial. AM reception is normal. I replaced the 7F8 tube and experienced a very slight improvement. Electrolytics were replaced several years ago, but everything is as it came from the factory.
For what it's worth, there was a considerable amount of transformer wax in 7F8 tube socket - likely formed prior to the electrolytic replacements. I cleaned it as best I could.
Any suggestions on how to approach this issue would be greatly appreciated.
1/14/2010 5:29:52 PMDave Froehlich
Bill,
Distortion on FM usually happens when one of the diodes don't work in the discriminator (FM Detector) circuit. Maybe a pin isn't connecting too well on the socket. Maybe a wire isn't connected or soldered well to a solder tab on the tube socket, involving the diodes. The capacitors in that circuit may be leaky as well. Think of it as both a full wave rectifier circuit with a filter capacitor and a push pull out put both at the same time. In a push pull output circuit, if one of the tubes doesn't work the sound will be distorted. In a power supply, if the filter capacitors aren't working, there will be ripple. It could be something else but this is what I have found where there's distorted FM.
I hope that this helps,
:My Philco 46-1213 recently developed distortion throughout the FM band, worse at the higher end of the dial. AM reception is normal. I replaced the 7F8 tube and experienced a very slight improvement. Electrolytics were replaced several years ago, but everything is as it came from the factory.
:For what it's worth, there was a considerable amount of transformer wax in 7F8 tube socket - likely formed prior to the electrolytic replacements. I cleaned it as best I could.
:Any suggestions on how to approach this issue would be greatly appreciated.
1/14/2010 5:31:32 PMDave Froehlich
Bill,
The "filter" capacitor in the FM detector is a paper capacitor in many cases. Did you also replace all the paper capacitors in your radio?
:Bill,
: Distortion on FM usually happens when one of the diodes don't work in the discriminator (FM Detector) circuit. Maybe a pin isn't connecting too well on the socket. Maybe a wire isn't connected or soldered well to a solder tab on the tube socket, involving the diodes. The capacitors in that circuit may be leaky as well. Think of it as both a full wave rectifier circuit with a filter capacitor and a push pull out put both at the same time. In a push pull output circuit, if one of the tubes doesn't work the sound will be distorted. In a power supply, if the filter capacitors aren't working, there will be ripple. It could be something else but this is what I have found where there's distorted FM.
:I hope that this helps,
:Dave
::My Philco 46-1213 recently developed distortion throughout the FM band, worse at the higher end of the dial. AM reception is normal. I replaced the 7F8 tube and experienced a very slight improvement. Electrolytics were replaced several years ago, but everything is as it came from the factory.
::For what it's worth, there was a considerable amount of transformer wax in 7F8 tube socket - likely formed prior to the electrolytic replacements. I cleaned it as best I could.
::Any suggestions on how to approach this issue would be greatly appreciated.
1/14/2010 8:20:23 PMBill Vaughan
Dave,
Thanks for the quick and helpful response. I'll check the tube sockets tonight.
Beside the electrolytics, the only caps that I replaced were C424, C205, C206 and C209. I did this just today following the advice of a circa 1954 version of the Philco Service Supervisor. No improvement. The remaining caps are all original and weren't changed as the radio worked fine for the past several years. Perhaps, it's time to change them, at least in the FM detector circuit.
Bill
:Bill,
: The "filter" capacitor in the FM detector is a paper capacitor in many cases. Did you also replace all the paper capacitors in your radio?
:Dave
::Bill,
:: Distortion on FM usually happens when one of the diodes don't work in the discriminator (FM Detector) circuit. Maybe a pin isn't connecting too well on the socket. Maybe a wire isn't connected or soldered well to a solder tab on the tube socket, involving the diodes. The capacitors in that circuit may be leaky as well. Think of it as both a full wave rectifier circuit with a filter capacitor and a push pull out put both at the same time. In a push pull output circuit, if one of the tubes doesn't work the sound will be distorted. In a power supply, if the filter capacitors aren't working, there will be ripple. It could be something else but this is what I have found where there's distorted FM.
::I hope that this helps,
::Dave
:::My Philco 46-1213 recently developed distortion throughout the FM band, worse at the higher end of the dial. AM reception is normal. I replaced the 7F8 tube and experienced a very slight improvement. Electrolytics were replaced several years ago, but everything is as it came from the factory.
:::For what it's worth, there was a considerable amount of transformer wax in 7F8 tube socket - likely formed prior to the electrolytic replacements. I cleaned it as best I could.
:::Any suggestions on how to approach this issue would be greatly appreciated.
1/15/2010 3:29:27 AMEdd
Sir Bill . . . . . .
After looking the schematic of your FM portion of that unit looks like that you are working with a completely different animal in the respect of the FM portion of that set and its resultant end FM detection circuitry.
No Discriminator . . . no Ratio Detector . . . therefore no diodes nor dried out summing electrolytics to worry about.
Instead, your set is using an I.F. frequency locked oscillator in the detector stage and is dependent upon quadrature detection in that stage for your FM to AF signal conversion.
Lets explore these possibilities initially:
Fully unplug and plug in that FM1000 tube about 6 times to get some contact scraping and cleaning action.
Now after starting up the set, it certainly wouldn't hurt to give the tube a couple of thumps on its top to see if any shift in audio quality performance is experienced.
If no abnormalities are being found right off. . . .
Then:
You need to be tuned RIGHT on to the received station, this can be done aurally or one can be ever so more exacting by the monitoring of pin 6 [A] of the 7H7 limiter tube. When you are optimally tuned to the station, the negative read out voltage on that test point will be at its max.
This is best done with a VTVM due to its minumal loading but could be minimally done with a 20k per volt VOM akin to a Simpson 260 or Triplett 600 series.
The fault with using a digital is its time lag in readout change and accompanying digit bobbling before resettling, unless it also has a companion analog "hash mark" scale.
Next step will be the locating of the C93 [C] trimmer capacitor marked on the schematic and shown on the parts profile to the side of the schematic.
Mark the units screw slot of its adjustment screw by making a reference mark at its side to the can assenbly.
Try a slow adjustment 1/4 turn to the right and then back to the start and then 1/4 turn in the opposite direction.
The end result being . . . if the produced FM sound clears up on the set, . . . and the adjustment is then left for the best sound from the unit.
FM audio output from the set is originating at C51/R31 [B] and is then routed down to Sections Q and R of the push button function selector switch assembly, where that FM audio is routed back up to the volume control, if in the
FM position.
REFERENCING: . . .of partial detector stage section . . .
1/15/2010 4:27:32 PMDave Froehlich
Edd,
Sorry, I shouldn't have said anything before looking at the schematic first. I need to learn about this type of FM detection too. I am just beginning to understand the diode type discriminator.
I know of quadrature detection but I don't understand how it works, yet. So this topic is very interesting.
:Sir Bill . . . . . .
:After looking the schematic of your FM portion of that unit looks like that you are working with a completely different animal in the respect of the FM portion of that set and its resultant end FM detection circuitry.
:No Discriminator . . . no Ratio Detector . . . therefore no diodes nor dried out summing electrolytics to worry about.
:Instead, your set is using an I.F. frequency locked oscillator in the detector stage and is dependent upon quadrature detection in that stage for your FM to AF signal conversion.
:Lets explore these possibilities initially:
:Fully unplug and plug in that FM1000 tube about 6 times to get some contact scraping and cleaning action.
:Now after starting up the set, it certainly wouldn't hurt to give the tube a couple of thumps on its top to see if any shift in audio quality performance is experienced.
: If no abnormalities are being found right off. . . .
:Then:
:You need to be tuned RIGHT on to the received station, this can be done aurally or one can be ever so more exacting by the monitoring of pin 6 [A] of the 7H7 limiter tube. When you are optimally tuned to the station, the negative read out voltage on that test point will be at its max.
:This is best done with a VTVM due to its minumal loading but could be minimally done with a 20k per volt VOM akin to a Simpson 260 or Triplett 600 series.
:The fault with using a digital is its time lag in readout change and accompanying digit bobbling before resettling, unless it also has a companion analog "hash mark" scale.
:Next step will be the locating of the C93 [C] trimmer capacitor marked on the schematic and shown on the parts profile to the side of the schematic.
:Mark the units screw slot of its adjustment screw by making a reference mark at its side to the can assenbly.
:Try a slow adjustment 1/4 turn to the right and then back to the start and then 1/4 turn in the opposite direction.
:The end result being . . . if the produced FM sound clears up on the set, . . . and the adjustment is then left for the best sound from the unit.
:FM audio output from the set is originating at C51/R31 [B] and is then routed down to Sections Q and R of the push button function selector switch assembly, where that FM audio is routed back up to the volume control, if in the
:FM position.
:REFERENCING: . . .of partial detector stage section . . .
1/15/2010 6:41:11 AMbill
Bill - This may not be a big help . I am not an expert but have one of these radios. I fought the Fm on mine also until I found a bad tube socket . After that adjustments worked and stuck.Before that find it behaved differently every time I turned it on.Also one odd thing one this set is four little pieces of rubber tape that are under the 7f8 I think .They are on top of the tube socket so that the metal tube case does not hit the chasis. That has been discussed here and can be search out most likley.Poeple see that and want to take them off.I am not so good at injecting a signal and seeing where it stops or is not right. Mainly becuase I find most problems with a meter or just by looking.Found the bad socket by wiggling the tube.Not sure what is in the If cans here. If I see rubber wire I take apart cans and sleeve . Usually no paper caps in there . But it is worth an inspection
to take it off your mind . If you have one that is weird with a lot of wax be careful it does not pull out wires when you take it apart . What I can tell you is it is a decent radio worth fixing in the end. Good luck !
1/15/2010 12:36:27 PMcindy
:Bill - This may not be a big help . I am not an expert but have one of these radios. I fought the Fm on mine also until I found a bad tube socket . After that adjustments worked and stuck.Before that find it behaved differently every time I turned it on.Also one odd thing one this set is four little pieces of rubber tape that are under the 7f8 I think .They are on top of the tube socket so that the metal tube case does not hit the chasis. That has been discussed here and can be search out most likley.Poeple see that and want to take them off.I am not so good at injecting a signal and seeing where it stops or is not right. Mainly becuase I find most problems with a meter or just by looking.Found the bad socket by wiggling the tube.Not sure what is in the If cans here. If I see rubber wire I take apart cans and sleeve . Usually no paper caps in there . But it is worth an inspection
:to take it off your mind . If you have one that is weird with a lot of wax be careful it does not pull out wires when you take it apart . What I can tell you is it is a decent radio worth fixing in the end. Good luck !
You might try using a tip cleaner for arc welders. The small round files on these would be excellent to grab the wax out of the sockets. The one I use says, "WYPO Tip Cleaner, Forney arc welders". I am sure they are very inexpensive. Just trying to help.
1/24/2010 1:40:11 AMBill Vaughan
::Bill - This may not be a big help . I am not an expert but have one of these radios. I fought the Fm on mine also until I found a bad tube socket . After that adjustments worked and stuck.Before that find it behaved differently every time I turned it on.Also one odd thing one this set is four little pieces of rubber tape that are under the 7f8 I think .They are on top of the tube socket so that the metal tube case does not hit the chasis. That has been discussed here and can be search out most likley.Poeple see that and want to take them off.I am not so good at injecting a signal and seeing where it stops or is not right. Mainly becuase I find most problems with a meter or just by looking.Found the bad socket by wiggling the tube.Not sure what is in the If cans here. If I see rubber wire I take apart cans and sleeve . Usually no paper caps in there . But it is worth an inspection
::to take it off your mind . If you have one that is weird with a lot of wax be careful it does not pull out wires when you take it apart . What I can tell you is it is a decent radio worth fixing in the end. Good luck !
:You might try using a tip cleaner for arc welders. The small round files on these would be excellent to grab the wax out of the sockets. The one I use says, "WYPO Tip Cleaner, Forney arc welders". I am sure they are very inexpensive. Just trying to help.
1/24/2010 5:00:42 AMW-I-D-T-H Correction . . .
as the upper text had s t r e t c h e d o u t to being the same width as the schema having been placed at the bottom . . .
Then:
FM position.
Addenda:
As per the additional comment on presence of "transformer wax" (expected to be a parrafin /or/ beeswax blend) and it originating on top / and flowing down inside of the FM RF/Mixer 7F8 tube socket, common Klean Strip, Crown or Solex brand of mineral spirits does a good final dissolving away of any traces that type of deposit.
ALSO , questioning, as to whether that wax seemed to have had its ORIGIN ? from the top of the chassis (2nd I.F. Transformer ?)and having run down INTO the 7F8 (FM mixer-osc tube), and got into the sockets pins.
OR , if being at the totally other end of the spectrum, if that wax was a heavier yellow, it may have actually been applied there from the bottom of the set to mechanically stabilize circuit components / movement of the potentially mechanically touchy FM OSCILLATOR section.
(Just firmly thump the 7F8 and see what I mean)
Now,if the created distortion is associative with THAT area of the set, I tend to expect it to be from freq drift after warm up and the distortion could then be cleared up by a slight re tune onto the station WHILE problems that I am referring to back in the FM detector stage, would not respond to that type of a temporary corrective action.
1/25/2010 6:17:37 PMBill Vaughan
Thank you, Sir.
I am expecting delivery of the remaining new caps tomorrow and will give your procedure a shot after I install them.
:as the upper text had s t r e t c h e d o u t to being the same width as the schema having been placed at the bottom . . .
:Then:
:FM position.
:Addenda:
:As per the additional comment on presence of "transformer wax" (expected to be a parrafin /or/ beeswax blend) and it originating on top / and flowing down inside of the FM RF/Mixer 7F8 tube socket, common Klean Strip, Crown or Solex brand of mineral spirits does a good final dissolving away of any traces that type of deposit.
:ALSO , questioning, as to whether that wax seemed to have had its ORIGIN ? from the top of the chassis (2nd I.F. Transformer ?)and having run down INTO the 7F8 (FM mixer-osc tube), and got into the sockets pins.
: OR , if being at the totally other end of the spectrum, if that wax was a heavier yellow, it may have actually been applied there from the bottom of the set to mechanically stabilize circuit components / movement of the potentially mechanically touchy FM OSCILLATOR section.
:(Just firmly thump the 7F8 and see what I mean)
:Now,if the created distortion is associative with THAT area of the set, I tend to expect it to be from freq drift after warm up and the distortion could then be cleared up by a slight re tune onto the station WHILE problems that I am referring to back in the FM detector stage, would not respond to that type of a temporary corrective action.
1/27/2010 6:18:58 PMBill Vaughan
Well, all paper caps have been replaced and although the set operates much better (more power, more stations), there remains some distortion on the weaker FM stations. Adjusting C93 resulted in no improvement. I've ordered a new FM1000 tube and hope that cures the problem. If not, it's on to the painful alignment process.
:Thank you, Sir.
:I am expecting delivery of the remaining new caps tomorrow and will give your procedure a shot after I install them.
::as the upper text had s t r e t c h e d o u t to being the same width as the schema having been placed at the bottom . . .
::Sir Bill . . . . . .
::After looking the schematic of your FM portion of that unit looks like that you are working with a completely different animal in the respect of the FM portion of that set and its resultant end FM detection circuitry.
::No Discriminator . . . no Ratio Detector . . . therefore no diodes nor dried out summing electrolytics to worry about.
::Instead, your set is using an I.F. frequency locked oscillator in the detector stage and is dependent upon quadrature detection in that stage for your FM to AF signal conversion.
::Lets explore these possibilities initially:
::Fully unplug and plug in that FM1000 tube about 6 times to get some contact scraping and cleaning action.
::Now after starting up the set, it certainly wouldn't hurt to give the tube a couple of thumps on its top to see if any shift in audio quality performance is experienced.
:: If no abnormalities are being found right off. . . .
::Then:
::You need to be tuned RIGHT on to the received station, this can be done aurally or one can be ever so more exacting by the monitoring of pin 6 [A] of the 7H7 limiter tube. When you are optimally tuned to the station, the negative read out voltage on that test point will be at its max.
::This is best done with a VTVM due to its minumal loading but could be minimally done with a 20k per volt VOM akin to a Simpson 260 or Triplett 600 series.
::The fault with using a digital is its time lag in readout change and accompanying digit bobbling before resettling, unless it also has a companion analog "hash mark" scale.
::Next step will be the locating of the C93 [C] trimmer capacitor marked on the schematic and shown on the parts profile to the side of the schematic.
::Mark the units screw slot of its adjustment screw by making a reference mark at its side to the can assenbly.
::Try a slow adjustment 1/4 turn to the right and then back to the start and then 1/4 turn in the opposite direction.
::The end result being . . . if the produced FM sound clears up on the set, . . . and the adjustment is then left for the best sound from the unit.
::FM audio output from the set is originating at C51/R31 [B] and is then routed down to Sections Q and R of the push button function selector switch assembly, where that FM audio is routed back up to the volume control, if in the
::FM position.
::Addenda:
::As per the additional comment on presence of "transformer wax" (expected to be a parrafin /or/ beeswax blend) and it originating on top / and flowing down inside of the FM RF/Mixer 7F8 tube socket, common Klean Strip, Crown or Solex brand of mineral spirits does a good final dissolving away of any traces that type of deposit.
::ALSO , questioning, as to whether that wax seemed to have had its ORIGIN ? from the top of the chassis (2nd I.F. Transformer ?)and having run down INTO the 7F8 (FM mixer-osc tube), and got into the sockets pins.
:: OR , if being at the totally other end of the spectrum, if that wax was a heavier yellow, it may have actually been applied there from the bottom of the set to mechanically stabilize circuit components / movement of the potentially mechanically touchy FM OSCILLATOR section.
::(Just firmly thump the 7F8 and see what I mean)
::Now,if the created distortion is associative with THAT area of the set, I tend to expect it to be from freq drift after warm up and the distortion could then be cleared up by a slight re tune onto the station WHILE problems that I am referring to back in the FM detector stage, would not respond to that type of a temporary corrective action.
::73's de Edd
::REFERENCING: . . .of partial detector stage section . . .
1/27/2010 7:16:59 PMEdd
BEFORE biting the bear:
Might I ask, if back before you touched up the C93 cap adjustment in the FM detector stage, did you perform the testing
of the negative DC voltage on the 1st grid (Pin 6) of the 7H7 limiter stage?
If not , you can find out a lot about the overall ” health” of the TUNING of the prior F.M. I.F. stages just by the monitoring of that voltage.
A Partial Repeating:
While monitoring (Pin 6) of the 7H7:
You need the sets tuning condenser to be set initially for a peak negative voltage on a strong station and leave it set there.
Then perform a CW-CCW , slightly on/off from the tuning, of the FOUND setting of EACH FM IF transformer, on down the line in the prior stages, one wants a peaked reading.
That overall procedure, being in order to see if that voltage increases, thus a prior stage had timely drifted a bit off from optimum tune.
The readout is not as pronounced, but you can also move forward to the pin 6 of the FM1000 to additionally include the 2 adjustments of T5 that
is just before the detector stage.
To initially get some idea, when moving metering to that new test point , move the tuning condenser slightly off station to see the voltage swing effect of a reduced signal effect, and then return the tuning condenser to its previously peak position again. Then check the 2 FM adjustment portions of T5.
Finally, disconnect and re evaluate your results on those particular received stations problems.
:Well, all paper caps have been replaced and although the set operates much better (more power, more stations), there remains some distortion on the weaker FM stations. Adjusting C93 resulted in no improvement. I've ordered a new FM1000 tube and hope that cures the problem. If not, it's on to the painful alignment process.
::Thank you, Sir.
::I am expecting delivery of the remaining new caps tomorrow and will give your procedure a shot after I install them.
:::as the upper text had s t r e t c h e d o u t to being the same width as the schema having been placed at the bottom . . .
:::Sir Bill . . . . . .
:::After looking the schematic of your FM portion of that unit looks like that you are working with a completely different animal in the respect of the FM portion of that set and its resultant end FM detection circuitry.
:::No Discriminator . . . no Ratio Detector . . . therefore no diodes nor dried out summing electrolytics to worry about.
:::Instead, your set is using an I.F. frequency locked oscillator in the detector stage and is dependent upon quadrature detection in that stage for your FM to AF signal conversion.
:::Lets explore these possibilities initially:
:::Fully unplug and plug in that FM1000 tube about 6 times to get some contact scraping and cleaning action.
:::Now after starting up the set, it certainly wouldn't hurt to give the tube a couple of thumps on its top to see if any shift in audio quality performance is experienced.
::: If no abnormalities are being found right off. . . .
:::Then:
:::You need to be tuned RIGHT on to the received station, this can be done aurally or one can be ever so more exacting by the monitoring of pin 6 [A] of the 7H7 limiter tube. When you are optimally tuned to the station, the negative read out voltage on that test point will be at its max.
:::This is best done with a VTVM due to its minumal loading but could be minimally done with a 20k per volt VOM akin to a Simpson 260 or Triplett 600 series.
:::The fault with using a digital is its time lag in readout change and accompanying digit bobbling before resettling, unless it also has a companion analog "hash mark" scale.
:::Next step will be the locating of the C93 [C] trimmer capacitor marked on the schematic and shown on the parts profile to the side of the schematic.
:::Mark the units screw slot of its adjustment screw by making a reference mark at its side to the can assenbly.
:::Try a slow adjustment 1/4 turn to the right and then back to the start and then 1/4 turn in the opposite direction.
:::The end result being . . . if the produced FM sound clears up on the set, . . . and the adjustment is then left for the best sound from the unit.
:::FM audio output from the set is originating at C51/R31 [B] and is then routed down to Sections Q and R of the push button function selector switch assembly, where that FM audio is routed back up to the volume control, if in the
:::FM position.
:::Addenda:
:::As per the additional comment on presence of "transformer wax" (expected to be a parrafin /or/ beeswax blend) and it originating on top / and flowing down inside of the FM RF/Mixer 7F8 tube socket, common Klean Strip, Crown or Solex brand of mineral spirits does a good final dissolving away of any traces that type of deposit.
:::ALSO , questioning, as to whether that wax seemed to have had its ORIGIN ? from the top of the chassis (2nd I.F. Transformer ?)and having run down INTO the 7F8 (FM mixer-osc tube), and got into the sockets pins.
::: OR , if being at the totally other end of the spectrum, if that wax was a heavier yellow, it may have actually been applied there from the bottom of the set to mechanically stabilize circuit components / movement of the potentially mechanically touchy FM OSCILLATOR section.
:::(Just firmly thump the 7F8 and see what I mean)
:::Now,if the created distortion is associative with THAT area of the set, I tend to expect it to be from freq drift after warm up and the distortion could then be cleared up by a slight re tune onto the station WHILE problems that I am referring to back in the FM detector stage, would not respond to that type of a temporary corrective action.
:::73's de Edd
:::REFERENCING: . . .of partial detector stage section . . .
1/27/2010 11:28:30 PMBill Vaughan
Good point. I did not attempt that procedure yet. If the new FM1000 tube doesn't correct the issue, that will be my next step.
:BEFORE biting the bear:
:Might I ask, if back before you touched up the C93 cap adjustment in the FM detector stage, did you perform the testing
:of the negative DC voltage on the 1st grid (Pin 6) of the 7H7 limiter stage?
:If not , you can find out a lot about the overall ” health” of the TUNING of the prior F.M. I.F. stages just by the monitoring of that voltage.
:A Partial Repeating:
:While monitoring (Pin 6) of the 7H7:
:You need the sets tuning condenser to be set initially for a peak negative voltage on a strong station and leave it set there.
:Then perform a CW-CCW , slightly on/off from the tuning, of the FOUND setting of EACH FM IF transformer, on down the line in the prior stages, one wants a peaked reading.
:That overall procedure, being in order to see if that voltage increases, thus a prior stage had timely drifted a bit off from optimum tune.
:The readout is not as pronounced, but you can also move forward to the pin 6 of the FM1000 to additionally include the 2 adjustments of T5 that
: is just before the detector stage.
:To initially get some idea, when moving metering to that new test point , move the tuning condenser slightly off station to see the voltage swing effect of a reduced signal effect, and then return the tuning condenser to its previously peak position again. Then check the 2 FM adjustment portions of T5.
:Finally, disconnect and re evaluate your results on those particular received stations problems.
::Well, all paper caps have been replaced and although the set operates much better (more power, more stations), there remains some distortion on the weaker FM stations. Adjusting C93 resulted in no improvement. I've ordered a new FM1000 tube and hope that cures the problem. If not, it's on to the painful alignment process.
:::Thank you, Sir.
:::I am expecting delivery of the remaining new caps tomorrow and will give your procedure a shot after I install them.
::::as the upper text had s t r e t c h e d o u t to being the same width as the schema having been placed at the bottom . . .
::::Sir Bill . . . . . .
::::After looking the schematic of your FM portion of that unit looks like that you are working with a completely different animal in the respect of the FM portion of that set and its resultant end FM detection circuitry.
::::No Discriminator . . . no Ratio Detector . . . therefore no diodes nor dried out summing electrolytics to worry about.
::::Instead, your set is using an I.F. frequency locked oscillator in the detector stage and is dependent upon quadrature detection in that stage for your FM to AF signal conversion.
::::Lets explore these possibilities initially:
::::Fully unplug and plug in that FM1000 tube about 6 times to get some contact scraping and cleaning action.
::::Now after starting up the set, it certainly wouldn't hurt to give the tube a couple of thumps on its top to see if any shift in audio quality performance is experienced.
:::: If no abnormalities are being found right off. . . .
::::Then:
::::You need to be tuned RIGHT on to the received station, this can be done aurally or one can be ever so more exacting by the monitoring of pin 6 [A] of the 7H7 limiter tube. When you are optimally tuned to the station, the negative read out voltage on that test point will be at its max.
::::This is best done with a VTVM due to its minumal loading but could be minimally done with a 20k per volt VOM akin to a Simpson 260 or Triplett 600 series.
::::The fault with using a digital is its time lag in readout change and accompanying digit bobbling before resettling, unless it also has a companion analog "hash mark" scale.
::::Next step will be the locating of the C93 [C] trimmer capacitor marked on the schematic and shown on the parts profile to the side of the schematic.
::::Mark the units screw slot of its adjustment screw by making a reference mark at its side to the can assenbly.
::::Try a slow adjustment 1/4 turn to the right and then back to the start and then 1/4 turn in the opposite direction.
::::The end result being . . . if the produced FM sound clears up on the set, . . . and the adjustment is then left for the best sound from the unit.
::::FM audio output from the set is originating at C51/R31 [B] and is then routed down to Sections Q and R of the push button function selector switch assembly, where that FM audio is routed back up to the volume control, if in the
::::FM position.
::::Addenda:
::::As per the additional comment on presence of "transformer wax" (expected to be a parrafin /or/ beeswax blend) and it originating on top / and flowing down inside of the FM RF/Mixer 7F8 tube socket, common Klean Strip, Crown or Solex brand of mineral spirits does a good final dissolving away of any traces that type of deposit.
::::ALSO , questioning, as to whether that wax seemed to have had its ORIGIN ? from the top of the chassis (2nd I.F. Transformer ?)and having run down INTO the 7F8 (FM mixer-osc tube), and got into the sockets pins.
:::: OR , if being at the totally other end of the spectrum, if that wax was a heavier yellow, it may have actually been applied there from the bottom of the set to mechanically stabilize circuit components / movement of the potentially mechanically touchy FM OSCILLATOR section.
::::(Just firmly thump the 7F8 and see what I mean)
::::Now,if the created distortion is associative with THAT area of the set, I tend to expect it to be from freq drift after warm up and the distortion could then be cleared up by a slight re tune onto the station WHILE problems that I am referring to back in the FM detector stage, would not respond to that type of a temporary corrective action.
::::73's de Edd
::::REFERENCING: . . .of partial detector stage section . . .
1/28/2010 11:39:56 AMThomas Dermody
...A few other points to keep in mind as well: A couple of years ago I took great interest in simple FM receivers. The two circuits that came up the most were the super regenerative receiver, and the detecting method your radio employs. I do know for sure that it was mentioned that the super regenerative receiver would have some trouble with the stereo sub-carrier broadcasted from most modern commercial stations, and the one I built did produce some distortion and noise with some of the stereo signals. I believe that your style of detector was also mentioned to have trouble with modern stereo signals--that you'd receive them, but with some hissing and heterodyning from the stereo sub-carrier. You say that the radio has performed well for the past few years, but perhaps there is something in your home that might be causing a similar problem, such as a new wireless router. ...Just a suggestion, but probably not the answer.
Also, the second point I wanted to make is that so far noone has suggested checking the resistors for drifting and opening. They do occasionally do this, and a change in voltage or bias might cause distortion of some sort.
1/30/2010 10:43:48 AMBill Vaughan
Interesting. I hope that the stereo signal isn't the actual cause of the problem - no solution for that one. I did install a wireless router a few years ago, too.
Although none of the resistors look bad, I'll check the values of the larger ones to make sure that they're still within spec.
Thanks.
:...A few other points to keep in mind as well: A couple of years ago I took great interest in simple FM receivers. The two circuits that came up the most were the super regenerative receiver, and the detecting method your radio employs. I do know for sure that it was mentioned that the super regenerative receiver would have some trouble with the stereo sub-carrier broadcasted from most modern commercial stations, and the one I built did produce some distortion and noise with some of the stereo signals. I believe that your style of detector was also mentioned to have trouble with modern stereo signals--that you'd receive them, but with some hissing and heterodyning from the stereo sub-carrier. You say that the radio has performed well for the past few years, but perhaps there is something in your home that might be causing a similar problem, such as a new wireless router. ...Just a suggestion, but probably not the answer.
:Also, the second point I wanted to make is that so far noone has suggested checking the resistors for drifting and opening. They do occasionally do this, and a change in voltage or bias might cause distortion of some sort.
:T.
1/30/2010 5:54:13 PMEdd
IF that actually does prove to be the case , the stereo subcarrier and the upper sidebands could possibly be cut with a parallel tuned inline and a series trap providing selective frequency filtering prior to the detector stage in 1st grid circuitry.
I was just initially relating it to touch up of the detector circuitry or process of the signsl STRENGTH thru the system, in touching upon fore submitted info.
Also you might pick out the problem stations and investigate with the stations engineering, what extra "baggage" might possibly be associated with their FM signal.Thereby equating to a possible cause of that stations less than stellar reception performance.
Specifically, subcarrier activity up at the 57Khz spectrum, with digital time and stations info possible there.
Then on up above 58Khz you might find a station using subcarriers there, in the past I have seen realtors using that on slow speed teletype data, Sunday services of a church in audio, reading of books for the blind and in times past a MUZAK type of elevator music, util they moved to satellite.
Possibly you could relate to the problem occuring after that time frame or possibly the unit was not used lately and the situation was not noticed . Most of my findings of that are related to problems way on up in the OLD analog TV frequencies.
A power up of the receiver and getting the reception in that failure mode , then a power shut down of the suspect offending electronics should answer that question.
:Interesting. I hope that the stereo signal isn't the actual cause of the problem - no solution for that one. I did install a wireless router a few years ago, too.
1/30/2010 7:32:18 PMThomas Dermody
I find that many wireless routers can destroy even low frequency AM reception, either due to sloppy transmission with lots of harmonics, or due to sloppy power supplies. My wireless router creates a lot of hiss and hum across my radio dial, and even into short wave, though not for FM, though all of my FM radios use conventional detection. My superregenerative receiver is currently disassembled. My neighbors have had wireless routers for a few years now, and theirs, too, have destroyed my DXing. Originally I wanted to build something that'd destroy their reception, since they did not honor my request to turn off their transmitters when not in use, but then a friend gave me an old laptop to fix and keep, and so I decided to instead join the crowd. BLA!
2/4/2010 1:33:04 AMBill Vaughan
Repair of the problem continues to elude me. I relocated to a detached garage to get away from the wireless router - no change. The new FM-1000 tube also failed to eliminate the distortion. A check of several key resistors revealed that they were all reasonably within spec. No smoking gun to be found.
My last hope is an alignment - something I'd been trying to avoid. Forgive this basic question, but can anyone help me identify the antenna section of the tuning gang (vs. the oscillator section)? I believe that it's the front section, but want to be certain before I proceed.
:I find that many wireless routers can destroy even low frequency AM reception, either due to sloppy transmission with lots of harmonics, or due to sloppy power supplies. My wireless router creates a lot of hiss and hum across my radio dial, and even into short wave, though not for FM, though all of my FM radios use conventional detection. My superregenerative receiver is currently disassembled. My neighbors have had wireless routers for a few years now, and theirs, too, have destroyed my DXing. Originally I wanted to build something that'd destroy their reception, since they did not honor my request to turn off their transmitters when not in use, but then a friend gave me an old laptop to fix and keep, and so I decided to instead join the crowd. BLA!
:T.
2/4/2010 6:04:18 PMEdd
Sir Bill. . . . . .
Indeed, that being a preliminalry next evaluation of there being maximum signal strength before further pursuits.
BTW was there every the trial of attaching a simple FM dipole external antenna made with folded 300 ohm twinline ?
The schematic versus its same physical layouts are included in the referencing below .
With the afore mentioned, monitoring of the 1st grid of the limiter, for a valid display of the effect of tuning.
Initially setting the main FM tuning condenser RIGHT on the station , then the trimmer adjustments affectation by the C27 and then the C33 mixer Rf trimmer adjustments.
Hopefully the remoting of the set to that distant locale , removed it away from all "modern electronics" interference sources, along with switch mode power electronic power supplies whines and hash, then possibly only excepting what is on the the incoming power line.
