:How do I test this bulb . It is a voltage regulator in my 1950's Navy RTTY converter (CV-89). I'm unsure of its condition . I'd like to be sure before I buy a new one even though it's not expensive and I'll troubleshoot from there. I have heard 110 volts AC with a resistor. Many thanks and happy new year !
:Andrew, here's aLamp Data Site.
:Handy data. Use your variac and hook/touch power cord to lamp. Turn up voltage until neon starts to glow both sides. For me that's good. You don't need to supply total voltage as chart indicates.
:Bill
::How do I test this bulb . It is a voltage regulator in my 1950's Navy RTTY converter (CV-89). I'm unsure of its condition . I'd like to be sure before I buy a new one even though it's not expensive and I'll troubleshoot from there. I have heard 110 volts AC with a resistor. Many thanks and happy new year !
:Bill
Your 991 will most likely be good but you can test it with a power supply, resistor and meter. Add a resistor in series with your 991. Connect the lamp/resistor across a power supply. The resistor value should be selected to give around 2 ma through the 991.
Measure voltage across the lamp. If good it should be between 48 and 67 volts.
http://www.mif.pg.gda.pl/homepages/frank/sheets/049/9/991.pdf
