HELP_BEGINNER_IN_NEED_URGENT
5/15/2001 6:01:00 PMBrad Rumenapp
Does anyone know what can be used instead of a diode(crystal)?
5/15/2001 6:06:32 PMNorm Leal
Hi Brad
Where will the diode be used? Radio Shack has many silicon diodes that can be used as rectifiers. The price is less than $1.00. If you need a diode for a crystal set use germanium. There are also diode tubes.
: Does anyone know what can be used instead of a diode(crystal)?
5/17/2001 3:12:25 PMJohn McPherson
Radio Shack also sells the 1N34A germaniums diodes in a pack.
: Hi Brad
: Where will the diode be used? Radio Shack has many silicon diodes that can be used as rectifiers. The price is less than $1.00. If you need a diode for a crystal set use germanium. There are also diode tubes.
: Norm
: : Does anyone know what can be used instead of a diode(crystal)?
