::First off test the CRT. I would bet it's weak and gassy. May check about re-built CRT if needed. Second the Flyback transfomer. Admial sets did burn up alot of there high voltage transformers. Check for open or shorted deflection yolk too. This would be a start to see if it's worth it or not.
:About the only thing that will be new is the horizontal circuity and the AGC, if it has AGC. The horiz synch. circuits are not anything in radio, and they produce the high Voltage for the CRT. The Vertical is a little hard to understand, but not too bad.
:Lewis
:Nor sure what u mean by CRT....deflection yolk?
:::First off test the CRT. I would bet it's weak and gassy. May check about re-built CRT if needed. Second the Flyback transfomer. Admial sets did burn up alot of there high voltage transformers. Check for open or shorted deflection yolk too. This would be a start to see if it's worth it or not.
::About the only thing that will be new is the horizontal circuity and the AGC, if it has AGC. The horiz synch. circuits are not anything in radio, and they produce the high Voltage for the CRT. The Vertical is a little hard to understand, but not too bad.
::Lewis
:Hi all I have been restoring radios for years and picked up a early 1950s Admiral TV I would like to restore ...Looking for someone who has worked on such and could throw a few pointers my way....I am aware that there will be HIGH volatge on this set...And lots of wire to replace (old and brittle) ..I will replace caps and resistor as needed..same as restoring old radios ..but what eles should I be aware of and any sites for picking up info on such Also all I have is a chassis # (30A1 s-e) and would liek to find a picture of my set or midel # ..THANKS FOR ANY SUGGESTIONS!!!
Hope this helps, Mark
:Ok after hrs of research I learned that my TV is a 1948 Admiral model # 30A1 Anyone know where I could find a schematic and DL it like we can here for radio schematics...THANKS!!
::Hi all I have been restoring radios for years and picked up a early 1950s Admiral TV I would like to restore ...Looking for someone who has worked on such and could throw a few pointers my way....I am aware that there will be HIGH volatge on this set...And lots of wire to replace (old and brittle) ..I will replace caps and resistor as needed..same as restoring old radios ..but what eles should I be aware of and any sites for picking up info on such Also all I have is a chassis # (30A1 s-e) and would liek to find a picture of my set or midel # ..THANKS FOR ANY SUGGESTIONS!!!
For a schematic, you might try Sams Photofact at http://www.sams.com or see if Antique Electronic Supply can sell you the schematic at http://www.tubesandmore.com
:I am hoping there is someone who use to restore old tvs in this forum (I have tried others with no luck)..I am restoring a 1948 Admiral #30A145 and need the "dog house" top cover or a chassis with good labels...
:I just ( 3 weeks ago) finished one of these. DO you have both chassis? or is there a power transformer mounted on that chssis you have? I didnt have many problems with mine, it is the console version.
:Good luck
::I am hoping there is someone who use to restore old tvs in this forum (I have tried others with no luck)..I am restoring a 1948 Admiral #30A145 and need the "dog house" top cover or a chassis with good labels...
:::Hi all I have been restoring radios for years and picked up a early 1950s Admiral TV I would like to restore ...Looking for someone who has worked on such and could throw a few pointers my way....I am aware that there will be HIGH volatge on this set...And lots of wire to replace (old and brittle) ..I will replace caps and resistor as needed..same as restoring old radios ..but what eles should I be aware of and any sites for picking up info on such Also all I have is a chassis # (30A1 s-e) and would liek to find a picture of my set or midel # ..THANKS FOR ANY SUGGESTIONS!!!
:Sir "George". . . . . .
:Looks like that power reee-sistor in question . . . and that is HEAV-EE on the power, located at the right
:rear chassis corner of the doghouse, is a 50 watter unit that is 500--500--5300 omegas in value.
:I think that the availability . . . EVER . . . of that doggie house top cover will be an impossibility, unless
:you make a midnight . . . wee hours . . . . visit to Sir Ians .
:A sheet metal fabricator . . . air conditioner duct fabricator . . . would only have to make 2 precise
:measurements of size and then two folds /bends plus a lip fold around and 4 spot welds on that lip to duplicate
:that original unit.
:BTW . . .MOST of the units I ever ran across had a small retainer chain attached to KEEP that cover unit
:nearby.
:Also my images detail precludes being able to differentiate as to whether the cover was aluminum
:or steel.
:BUT usually most steel units had louvers molded in for ventilation imstead of the 'lebenteen kazillion holes
:your main cage assembly shows.
:Guess that you will have to put a magnet to the present cage to see if the unit is steel or alum-i-ninny-yum-yum .
:That effect is also replicable by a fabricator if he merely scribes lines for the hole locations and then uses his
:pneumatic to punch the holes, of course, that would be the first thing to be done before the bends.
:A co-operative Ian should be able to check his unit and pass on the hole pattern and hole count of the unit
:which he has on his set.
:With what I see of this photos cage, it appears to me to as NOT having a flat paint finish on it, but possibly
:being made of aluminum and having a light anodizing and the use of a black analine dye then providing for
:the colorization of the unit.
:ALSO, I would thing that the possibilities of your picture tube not being in gassy low emisson state are
:certainly GREATLY improved with its snmall kine size versus the set being a larger 21-24-27 . . .or Dios
:Amanecio . . . a 30 inch round as was tried out on the old Hoffmans and Stromberg Carlsons.
:Foto: . . . . . (Getting down, inside the doghouse)
![]() Sir "George". . . . . Now, are you ‘rat sure on that power reee-sistor., my documentation lists it as sticking out of the conformal vitreous over coating.
series connected (2).500 ohm sections and their 2 bulging convolutions . . then the looong spacing of the 5300 ohm winding and then its end being at the very bottom.
the 500 ohm sections and then the final bulge out at the very bottom for the last terminal.
pages. But assuredly, they are hi power dropping resistors associated with the main power supply or the next current hog being the Hoz deflection circuit, with the vertical circuit being next in line.
:Edd In regards to the power resitor..they are using a 500 and a 5300 section together for 5800 ohms eeek...I think i have some of these in my supply...THANKS for the info !!!
::Sir "George". . . . . .
::Looks like that power reee-sistor in question . . . and that is HEAV-EE on the power, located at the right
::rear chassis corner of the doghouse, is a 50 watter unit that is 500--500--5300 omegas in value.
::I think that the availability . . . EVER . . . of that doggie house top cover will be an impossibility, unless
::you make a midnight . . . wee hours . . . . visit to Sir Ians .
::A sheet metal fabricator . . . air conditioner duct fabricator . . . would only have to make 2 precise
::measurements of size and then two folds /bends plus a lip fold around and 4 spot welds on that lip to duplicate
::that original unit.
::BTW . . .MOST of the units I ever ran across had a small retainer chain attached to KEEP that cover unit
::nearby.
::Also my images detail precludes being able to differentiate as to whether the cover was aluminum
::or steel.
::BUT usually most steel units had louvers molded in for ventilation imstead of the 'lebenteen kazillion holes
::your main cage assembly shows.
::Guess that you will have to put a magnet to the present cage to see if the unit is steel or alum-i-ninny-yum-yum .
::That effect is also replicable by a fabricator if he merely scribes lines for the hole locations and then uses his
::pneumatic to punch the holes, of course, that would be the first thing to be done before the bends.
::A co-operative Ian should be able to check his unit and pass on the hole pattern and hole count of the unit
::which he has on his set.
::With what I see of this photos cage, it appears to me to as NOT having a flat paint finish on it, but possibly
::being made of aluminum and having a light anodizing and the use of a black analine dye then providing for
::the colorization of the unit.
::ALSO, I would thing that the possibilities of your picture tube not being in gassy low emisson state are
::certainly GREATLY improved with its snmall kine size versus the set being a larger 21-24-27 . . .or Dios
::Amanecio . . . a 30 inch round as was tried out on the old Hoffmans and Stromberg Carlsons.
::Foto: . . . . . (Getting down, inside the doghouse)
::73's de Edd
:Now, are you ‘rat sure on that power reee-sistor., my documentation lists it as
:schematic symbol R98A . . . . Its being a 50 watt unit . . . and should have 4 straps / terminals
: sticking out of the conformal vitreous over coating.
:Matter of fact, I am looking at the photo now.
:In looking downwards from its top, seems like I can almost ? make out the short spacing between the
:series connected (2).500 ohm sections and their 2 bulging convolutions . . then the looong spacing of the 5300 ohm
:winding and then its end being at the very bottom.
:That shows up as an initial bulge out for the very top end terminal then two outward bulges between
: the 500 ohm sections and then the final bulge out at the very bottom for the last terminal.
:I did not trace down their circuit positions / functions, with its schematic using up all of two giant
: pages. But assuredly, they are hi power dropping resistors associated with the main power supply
:or the next current hog being the Hoz deflection circuit, with the vertical circuit being next in line.
::Edd In regards to the power resitor..they are using a 500 and a 5300 section together for 5800 ohms eeek...I think i have some of these in my supply...THANKS for the info !!!
:::Sir "George". . . . . .
:::Looks like that power reee-sistor in question . . . and that is HEAV-EE on the power, located at the right
:::rear chassis corner of the doghouse, is a 50 watter unit that is 500--500--5300 omegas in value.
:::I think that the availability . . . EVER . . . of that doggie house top cover will be an impossibility, unless
:::you make a midnight . . . wee hours . . . . visit to Sir Ians .
:::A sheet metal fabricator . . . air conditioner duct fabricator . . . would only have to make 2 precise
:::measurements of size and then two folds /bends plus a lip fold around and 4 spot welds on that lip to duplicate
:::that original unit.
:::BTW . . .MOST of the units I ever ran across had a small retainer chain attached to KEEP that cover unit
:::nearby.
:::Also my images detail precludes being able to differentiate as to whether the cover was aluminum
:::or steel.
:::BUT usually most steel units had louvers molded in for ventilation imstead of the 'lebenteen kazillion holes
:::your main cage assembly shows.
:::Guess that you will have to put a magnet to the present cage to see if the unit is steel or alum-i-ninny-yum-yum .
:::That effect is also replicable by a fabricator if he merely scribes lines for the hole locations and then uses his
:::pneumatic to punch the holes, of course, that would be the first thing to be done before the bends.
:::A co-operative Ian should be able to check his unit and pass on the hole pattern and hole count of the unit
:::which he has on his set.
:::With what I see of this photos cage, it appears to me to as NOT having a flat paint finish on it, but possibly
:::being made of aluminum and having a light anodizing and the use of a black analine dye then providing for
:::the colorization of the unit.
:::ALSO, I would thing that the possibilities of your picture tube not being in gassy low emisson state are
:::certainly GREATLY improved with its snmall kine size versus the set being a larger 21-24-27 . . .or Dios
:::Amanecio . . . a 30 inch round as was tried out on the old Hoffmans and Stromberg Carlsons.
:::Foto: . . . . . (Getting down, inside the doghouse)
:::73's de Edd
As for the HV cage, it is steel and flat black. I will try to get you more information (what do you need?)
Do you need the schematic? I have the photofact, but would need to scan it though. (not untill friday night/weekend)
Ian
:You are correct sir... My Tv is connected to the center tap between the two 500 ohm strips and at the bottom of the 5300 ohm strip....for a total of 5800 ohms...The very top 500 ohm section is not used...I do not have a schematic (waiting on one)..Could you verify for me? THANK YOU!!!
::Now, are you ‘rat sure on that power reee-sistor., my documentation lists it as
::schematic symbol R98A . . . . Its being a 50 watt unit . . . and should have 4 straps / terminals
:: sticking out of the conformal vitreous over coating.
::Matter of fact, I am looking at the photo now.
::In looking downwards from its top, seems like I can almost ? make out the short spacing between the
::series connected (2).500 ohm sections and their 2 bulging convolutions . . then the looong spacing of the 5300 ohm
::winding and then its end being at the very bottom.
::That shows up as an initial bulge out for the very top end terminal then two outward bulges between
:: the 500 ohm sections and then the final bulge out at the very bottom for the last terminal.
::I did not trace down their circuit positions / functions, with its schematic using up all of two giant
:: pages. But assuredly, they are hi power dropping resistors associated with the main power supply
::or the next current hog being the Hoz deflection circuit, with the vertical circuit being next in line.
::73's de Edd
:::Edd In regards to the power resitor..they are using a 500 and a 5300 section together for 5800 ohms eeek...I think i have some of these in my supply...THANKS for the info !!!
::::Sir "George". . . . . .
::::Looks like that power reee-sistor in question . . . and that is HEAV-EE on the power, located at the right
::::rear chassis corner of the doghouse, is a 50 watter unit that is 500--500--5300 omegas in value.
::::I think that the availability . . . EVER . . . of that doggie house top cover will be an impossibility, unless
::::you make a midnight . . . wee hours . . . . visit to Sir Ians .
::::A sheet metal fabricator . . . air conditioner duct fabricator . . . would only have to make 2 precise
::::measurements of size and then two folds /bends plus a lip fold around and 4 spot welds on that lip to duplicate
::::that original unit.
::::BTW . . .MOST of the units I ever ran across had a small retainer chain attached to KEEP that cover unit
::::nearby.
::::Also my images detail precludes being able to differentiate as to whether the cover was aluminum
::::or steel.
::::BUT usually most steel units had louvers molded in for ventilation imstead of the 'lebenteen kazillion holes
::::your main cage assembly shows.
::::Guess that you will have to put a magnet to the present cage to see if the unit is steel or alum-i-ninny-yum-yum .
::::That effect is also replicable by a fabricator if he merely scribes lines for the hole locations and then uses his
::::pneumatic to punch the holes, of course, that would be the first thing to be done before the bends.
::::A co-operative Ian should be able to check his unit and pass on the hole pattern and hole count of the unit
::::which he has on his set.
::::With what I see of this photos cage, it appears to me to as NOT having a flat paint finish on it, but possibly
::::being made of aluminum and having a light anodizing and the use of a black analine dye then providing for
::::the colorization of the unit.
::::ALSO, I would thing that the possibilities of your picture tube not being in gassy low emisson state are
::::certainly GREATLY improved with its snmall kine size versus the set being a larger 21-24-27 . . .or Dios
::::Amanecio . . . a 30 inch round as was tried out on the old Hoffmans and Stromberg Carlsons.
::::Foto: . . . . . (Getting down, inside the doghouse)
::::73's de Edd
:Yes, it should be on the center tap. (mine is) However, this resistror is in the horizontal damping circut. Mine Was also bad. The tv worked with it(~15meg ohms) but the linearity was awful. Once replaced, the picture went back to normal.
:As for the HV cage, it is steel and flat black. I will try to get you more information (what do you need?)
:Do you need the schematic? I have the photofact, but would need to scan it though. (not untill friday night/weekend)
:Ian
::You are correct sir... My Tv is connected to the center tap between the two 500 ohm strips and at the bottom of the 5300 ohm strip....for a total of 5800 ohms...The very top 500 ohm section is not used...I do not have a schematic (waiting on one)..Could you verify for me? THANK YOU!!!
:::Now, are you ‘rat sure on that power reee-sistor., my documentation lists it as
:::schematic symbol R98A . . . . Its being a 50 watt unit . . . and should have 4 straps / terminals
::: sticking out of the conformal vitreous over coating.
:::Matter of fact, I am looking at the photo now.
:::In looking downwards from its top, seems like I can almost ? make out the short spacing between the
:::series connected (2).500 ohm sections and their 2 bulging convolutions . . then the looong spacing of the 5300 ohm
:::winding and then its end being at the very bottom.
:::That shows up as an initial bulge out for the very top end terminal then two outward bulges between
::: the 500 ohm sections and then the final bulge out at the very bottom for the last terminal.
:::I did not trace down their circuit positions / functions, with its schematic using up all of two giant
::: pages. But assuredly, they are hi power dropping resistors associated with the main power supply
:::or the next current hog being the Hoz deflection circuit, with the vertical circuit being next in line.
:::73's de Edd
::::Edd In regards to the power resitor..they are using a 500 and a 5300 section together for 5800 ohms eeek...I think i have some of these in my supply...THANKS for the info !!!
:::::Sir "George". . . . . .
:::::Looks like that power reee-sistor in question . . . and that is HEAV-EE on the power, located at the right
:::::rear chassis corner of the doghouse, is a 50 watter unit that is 500--500--5300 omegas in value.
:::::I think that the availability . . . EVER . . . of that doggie house top cover will be an impossibility, unless
:::::you make a midnight . . . wee hours . . . . visit to Sir Ians .
:::::A sheet metal fabricator . . . air conditioner duct fabricator . . . would only have to make 2 precise
:::::measurements of size and then two folds /bends plus a lip fold around and 4 spot welds on that lip to duplicate
:::::that original unit.
:::::BTW . . .MOST of the units I ever ran across had a small retainer chain attached to KEEP that cover unit
:::::nearby.
:::::Also my images detail precludes being able to differentiate as to whether the cover was aluminum
:::::or steel.
:::::BUT usually most steel units had louvers molded in for ventilation imstead of the 'lebenteen kazillion holes
:::::your main cage assembly shows.
:::::Guess that you will have to put a magnet to the present cage to see if the unit is steel or alum-i-ninny-yum-yum .
:::::That effect is also replicable by a fabricator if he merely scribes lines for the hole locations and then uses his
:::::pneumatic to punch the holes, of course, that would be the first thing to be done before the bends.
:::::A co-operative Ian should be able to check his unit and pass on the hole pattern and hole count of the unit
:::::which he has on his set.
:::::With what I see of this photos cage, it appears to me to as NOT having a flat paint finish on it, but possibly
:::::being made of aluminum and having a light anodizing and the use of a black analine dye then providing for
:::::the colorization of the unit.
:::::ALSO, I would thing that the possibilities of your picture tube not being in gassy low emisson state are
:::::certainly GREATLY improved with its snmall kine size versus the set being a larger 21-24-27 . . .or Dios
:::::Amanecio . . . a 30 inch round as was tried out on the old Hoffmans and Stromberg Carlsons.
:::::Foto: . . . . . (Getting down, inside the doghouse)
:::::73's de Edd
:Ian
:::73's de Edd
:::::nearby.
:::::or steel.
:::::73's de Edd
::73's de Edd
::::nearby.
::::or steel.
::::73's de Edd
:My main porcelain power resistor which uses 5,800 homs at 50 W...is bad ...I am looking for one or one that has the moveable ajuster ...Any help? Where to find?
:::73's de Edd
:::::nearby.
:::::or steel.
:::::73's de Edd
:::73's de Edd
:::::nearby.
:::::or steel.
:::::73's de Edd
