Good luck-
Terry
Type then acquire the photo by highlighting the URL in properties
Then paste the URL in your post and type
Here it goes.
::::Chris, do you have anyplace to post a photo on the net. A lot of members use photobucket, I use myspace. Once you have the photo somewhere on the net, open your post and start your message to insert the curser in the body. Type in ::::then right click on your image, choose properties, use the curser to highlight the URL, (will end in jpg)then right click again on the highlight and choose copy. Close out the page. Make sure the curser is in the post again then go to edit and click paste. Then type >.
::::So it should look like this-
::::Then post- hopefully it'll work. A smaller , (VGA-email),size will look, and work, better than a huge photo.
::::Good luck-
::::Terry
:::Okay, you can see it works-
:::What to type to insert your photo should look like this-
:::Try it.
:Wow, it's rejecting my demonstration-
:let me try again
:Type :
:then acquire the photo by highlighting the URL in properties
:Then paste the URL in your post and type
:::::::I have a picture of the radio, but I don't see how to add the picture to this forum system. I can send it via email address above. I have found out that it is a Model 60 with RF Coil taps. Does anyone know if the radio takes O1A tubes? I would also like to know what year it is if anyone knows? Serial number is 3392. Anyone have an idea of the value of the radio?
::I put in the pic. Hope someone can tell me the year of the radio and the other questions I have.
::Here it goes.
::::::Chris, do you have anyplace to post a photo on the net. A lot of members use photobucket, I use myspace. Once you have the photo somewhere on the net, open your post and start your message to insert the curser in the body. Type in ::::::then right click on your image, choose properties, use the curser to highlight the URL, (will end in jpg)then right click again on the highlight and choose copy. Close out the page. Make sure the curser is in the post again then go to edit and click paste. Then type >.
::::::So it should look like this-
::::::Then post- hopefully it'll work. A smaller , (VGA-email),size will look, and work, better than a huge photo.
::::::Good luck-
::::::Terry
:::::Okay, you can see it works-
:::::What to type to insert your photo should look like this-
:::::Try it.
:::Wow, it's rejecting my demonstration-
:::let me try again
:::Type :::
:::then acquire the photo by highlighting the URL in properties
:::Then paste the URL in your post and type
