1/1/2010 10:01:32 PMBrian(82888:0)
I have a radio where there is an electrolytic 20 mfd connected to the cathode of the output tube. Without having a schematic, would the use of a capacitor rated at 450 volts have an adverse effect on performance? I recall reading something about this recently but cannot find it.
1/1/2010 10:42:20 PMWarren(82889:82888)
As long as it's 20 MFD that's okay. The over rate in voltage won't make any difference.
1/2/2010 1:59:24 AMPeter G. Balazsy(82892:82889)
That's called the "cathode by-pass" capacitor.
There's usually only about 5-10volts DC on the cathode of a typical 50L6 output tube as an example. So a low voltage 20uf cap will be fine.
You can measure the voltage and then find a cap of about twice that voltage rating.
A 20uf 25v cap can be found at radio shack or anywhere.
