Please help if you can.
Maybe it does exist. If you know where I can find it, please let me know.
:Hello All,
: Does anyone know what models of Silvertone wire recorders this amplifier chassis was used in? All I know so far is that it was a metal luggage type portable, that had a deck (different chassis number) that could also play 78RPM records. This amplifier has loktal tubes in it.
:Please help if you can.
:Thanks,
:Dave
Sure its o.k. on the paper versus electrolytic, on the input circuit of the other unit.
SILVERTONE. . . .Wire Recorder. . . . . SCHEMATIC: ![]() |
:Sir Dave. . . . . .
:Strange . . you usually end up getting with it and eventually answering your own questions .
:Sure its o.k. on the paper versus electrolytic, on the input circuit of the other unit.
:Don't have the data on the Fisher to confirm the ge /vs/ sil situation on its diodes.
:Pity that one of the screw in lamps was intact, so that you could confirm its voltage rating BUT
:MAINLY its current draw. Then select an according "grain of wheat" replacement lamp and
:solve the mechanical mounting and voltage / current altering to trim in to specs.
:I have wire recorder data on their two versions, of which the other is using octal tubes, so here is
:the one attached, that is using Loktal toobies.
:That should down right be FUN -CITY on that units meee-chanicals.
:SILVERTONE. . . .Wire Recorder. . . . . SCHEMATIC:
