Philco 26J / 19 / 89 extra caps... Help!
12/30/2009 11:28:40 PMBrett
O.K. I have a Philco 26J for all intents and purposes it is identical to a 19 and 89 using a 36 tube. But…it has an extra Bakelite condenser block and a 5 wire gang (that’s been cut) presumably to feed the phonograph that’s trashed along with the rest of the set. It also has an A.C. plug coming out the other end also presumably for the phono (that’s not a problem). I want to eliminate the extra Bakelite block but I’m not sure what wires go where. I’m getting better at schematics but could use a little help here. I’m not worried about the five gang wires but there are several other wires to the block I need to reroute. Anybody? Thanks, Brett
12/30/2009 11:33:51 PMBrett
:O.K. I have a Philco 26J for all intents and purposes it is identical to a 19 and 89 using a 36 tube. But…it has an extra Bakelite condenser block and a 5 wire gang (that’s been cut) presumably to feed the phonograph that’s trashed along with the rest of the set. It also has an A.C. plug coming out the other end also presumably for the phono (that’s not a problem). I want to eliminate the extra Bakelite block but I’m not sure what wires go where. I’m getting better at schematics but could use a little help here. I’m not worried about the five gang wires but there are several other wires to the block I need to reroute. Anybody? Thanks, Brett
:P.S. I want to use this chassis for my 89 that’s why I want to eliminate the gang and block.
