Output Voltage
12/28/2009 9:36:46 PMAndy
Does anyone know the OUTPUT VOLTAGE of a typical DISH or DIRECT TV BOX "AUDIO OUT" Connector? Thank You for any help.
12/29/2009 4:24:43 AMJohnnysan
:Does anyone know the OUTPUT VOLTAGE of a typical DISH or DIRECT TV BOX "AUDIO OUT" Connector? Thank You for any help.
It's probably line level, which is .775 volt peak.
12/29/2009 11:05:41 AMLewis L
::Does anyone know the OUTPUT VOLTAGE of a typical DISH or DIRECT TV BOX "AUDIO OUT" Connector? Thank You for any help.
:It's probably line level, which is .775 volt peak.
We were talking the other day about connecting something to a Magnavox, I think, phono input, and I said I had a rotary switch connected into the AUX jack of my stereo amplifier, and that CD, VCR, DVD, and SAT are alll about the same level when switched into my stereo amp.
12/29/2009 7:44:59 PMdrew
:::Does anyone know the OUTPUT VOLTAGE of a typical DISH or DIRECT TV BOX "AUDIO OUT" Connector? Thank You for any help.
::It's probably line level, which is .775 volt peak.
:Thanks for info. I tried it, It worked............
:We were talking the other day about connecting something to a Magnavox, I think, phono input, and I said I had a rotary switch connected into the AUX jack of my stereo amplifier, and that CD, VCR, DVD, and SAT are alll about the same level when switched into my stereo amp.
