Zenith TO B600 Dropping resistor on rectifier.
12/19/2009 5:58:51 PMDave Froehlich
Hello All,
I have forgotten what value of dropping resistor to use with a 1N400X diode. I think that I can use the existing dropping resistor (130 ohms). I think that's probably fine. 100 ohms seems to be too much and the 1L6 doesn't have enough current for the high frequencies. I'll first use the existing resistor.
12/19/2009 6:12:45 PMDave Froehlich
Hello All again,
Yes, that works fine. If there's a problem with this please let me know.
:Hello All,
: I have forgotten what value of dropping resistor to use with a 1N400X diode. I think that I can use the existing dropping resistor (130 ohms). I think that's probably fine. 100 ohms seems to be too much and the 1L6 doesn't have enough current for the high frequencies. I'll first use the existing resistor.
:Dave
