You could build a power supply to replace the vibrator section of your radio. Two voltages will be needed, 6 volt to light tubes and B+, around 135 volts.
6 volts can be AC from a filament transformer since your radio uses heater type tubes. An isolation transformer with rectifier and filter caps can be used for B+.
: My RCA uses a 6-volt battery and vibrator power supply. I have been unsuccessful in locating an appropriate replacement vibrator unit. Where can I locate one? Is it possible to build a solid state unit or convert the radio to A/C power?
Alternatively, yo might want to see if AES (www.tubesandmore.com) has a solid state replacement. I have seen them around, but I am not sure if it was AES, or another vendor.
: Hi Tony
: You could build a power supply to replace the vibrator section of your radio. Two voltages will be needed, 6 volt to light tubes and B+, around 135 volts.
: 6 volts can be AC from a filament transformer since your radio uses heater type tubes. An isolation transformer with rectifier and filter caps can be used for B+.
: Norm
: : My RCA uses a 6-volt battery and vibrator power supply. I have been unsuccessful in locating an appropriate replacement vibrator unit. Where can I locate one? Is it possible to build a solid state unit or convert the radio to A/C power?
