Just for fun I fired up the set in the tube tester mode - I
was hoping the two .5 MFD caps only functioned when the
multimeter mode was used. The "fuse lamp" had lost its slight
glow and I took this to mean the caps had been leaky.
The tester acted funny though. I tested some 12BA6 and
12BE6 tubes and got the same very low reading for a number of
tubes, regardless of new, used, previously tested good, or what.
I also tested a diode tube (6W4GT I think)and it pegged the
meter off the scale.
Was I an idiot to expect correct readings without replacing
those two .5 caps in the multimeter section, or is something
else going on like resistors out of spec? I have the caps
on order.
I would start with testing some diodes since those are emission only, and use less of the tester circuitry. Then progress to triodes to keep things simple.
