Tube testers
12/12/2009 4:09:17 PMJohnnyK
What should I be looking for when buying a tube tester? Any particular brands to look for, or Any particular brands to stay away from?
12/12/2009 4:30:05 PMTerry F
Most important to me is that they accept the types of tubes you are using. Check the pinout diagrams. Some testers don't accept the older four pin tubes, etc.
I had to get two different testers in order to test the range of tubes that I use.
Good luck.
Terry F
12/13/2009 6:48:09 PMSteve Simmons
:What should I be looking for when buying a tube tester? Any particular brands to look for, or Any particular brands to stay away from?
