I've heard that if the output doesn't have some kind of load it could fry something.
How important is it to hook them up or do they have to be there at all?
If you are only measuring power supply voltages or voltages at tube sockets, then an antenna and ground are not required.
For many sets, a speaker is required to be hooked up for the set to function at all. Speaker field coils serve as an important part of the radios power supply in many older sets.
Prolonged operation without a speaker is typically not recommended.
