Schematic for Telefunken Caprice 5451W
12/4/2009 7:46:16 AMRon
Appreciate if anyone can forward me a copy.
Thanks.
12/4/2009 3:30:08 PMDennis Wess
info sent
12/4/2009 4:02:05 PMRon
:info sent
12/4/2009 9:19:14 PMadamc
I recapped mine, and the sensitivity does not seem the best, and seems to sound overloaded & clipped on strong fm signals..
12/5/2009 9:54:54 AMRon
:I recapped mine, and the sensitivity does not seem the best, and seems to sound overloaded & clipped on strong fm signals..
12/10/2009 12:25:30 PMDennis Wess
Bad electro filter capacitors will ordinarily cause a/c hum that is NOT variable with the volume control. Would suggest you replace all paper/wax caps, check tubes and voltages, and also confirm the hum is not coming from an external source.
9/28/2010 9:20:49 PMENIO O PENATE
:Bad electro filter capacitors will ordinarily cause a/c hum that is NOT variable with the volume control. Would suggest you replace all paper/wax caps, check tubes and voltages, and also confirm the hum is not coming from an external source.
