Anti-fungal varnish used in WW II Military radios.
4/30/2001 10:42:12 AMOlaf,KF4TP
I am trying to find out,what used in those WW II military radios that had all the curcuitry and wiring covered with a greenish/yellowish varnish to treat against fungus and moisture.---Was it a varnish,shellac,lacquer,or what?What gave it the greenish /yellowish colour?---I am sure the stuff is no longer available,but may be some ''old timer''still knows what it was.----Thanks,Olaf---
4/30/2001 11:04:07 AMNorm Leal
Hi Olaf
The material was called Humi-Seal. It could be bought in spray cans and had different grades or types. The material smelled like varnish but can't be sure.
: I am trying to find out,what used in those WW II military radios that had all the curcuitry and wiring covered with a greenish/yellowish varnish to treat against fungus and moisture.---Was it a varnish,shellac,lacquer,or what?What gave it the greenish /yellowish colour?---I am sure the stuff is no longer available,but may be some ''old timer''still knows what it was.----Thanks,Olaf---
5/3/2001 6:47:28 AMAlan Douglas
I would guess it was a varnish (cured by cross-linking, rather than just solvent evaporation). I believe the fungicide was copper naphthenate, nasty stuff, and the fluorescent color was added to allow inspection under ultraviolet light.
7/1/2001 12:58:38 AMRobb Leamy
: I would guess it was a varnish (cured by cross-linking, rather than just solvent evaporation). I believe the fungicide was copper naphthenate, nasty stuff, and the fluorescent color was added to allow inspection under ultraviolet light.
Any chance this stuff is a health hazard? Should we be exercising any special cautions with it?
